Hey guys, Couple questions about an R for sale
Old Oct 29, 2002 | 04:00 PM
.Chris.'s Avatar
Default Hey guys, Couple questions about an R for sale
So I went and look at a 99 CW ITR for sale. It seems like a pretty good deal. I believe the car is clean of accidents etc. I wanna know that it is stock tho. The owner says it is altho as soon as a sat in it I noticed he had an aftremarket shifter. This makes me wonder abou the rest of the car being stock. What does the tail pipe look like?? can someone post a pic?
Also, is the trunk bar stock??
Anything else I should look for? I know most of the stuff on the car is stock, just a few Items I need to know about.
BTW, how do I know that the motor isnt fukked?
Old Oct 29, 2002 | 04:04 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Hey guys, Couple questions about an R for sale (Black204GSR)
I think you need to do a LOT more research on this car before you buy it if you dont even know if the motor is "fukked" Do some searches, look some R data pages up.
Old Oct 29, 2002 | 04:27 PM
.Chris.'s Avatar
Default Re: Hey guys, Couple questions about an R for sale (Rguy)
Actually dood, I do know a fair bit about the car. I know it has extra chassis bracing but i never heard that they had a trunk bar. As for the motor, I can tell if I drive it (which I will) how it performs, but is there a way to know what kind of condition the motor might be in without driving it I.E. checking oil etc. What are they prone to that is different than a B18C1?? Where are the engine codes located and where is the VIN#. is it on the windshield??
Old Oct 29, 2002 | 11:55 PM
AccrdATK's Avatar
New User
do a compression test
Old Oct 29, 2002 | 11:58 PM
Kelvin96GSR's Avatar
25 Year Member
locations are the same as the GSR. Rear Tower brace is standard. Do a compression test. check underneath the car for damage.
Old Oct 30, 2002 | 12:38 AM
Morphious's Avatar
From: In order to grasp victory,one must envision sucess
Default Re: Hey guys, Couple questions about an R for sale (Kelvin96GSR)
yyyyaaawwwwwnnnn....just call lemon busters or take it to honda and have them do a full body inspection. Its fairly cheap
Old Oct 30, 2002 | 12:57 AM
Kid1320's Avatar
what does CW stand for?
Old Oct 30, 2002 | 01:01 AM
Lucky-R's Avatar
this should answer most questions
http://66.81.7.238/zerothread?id=314109
Old Oct 30, 2002 | 12:36 PM
.Chris.'s Avatar
Default Re: Hey guys, Couple questions about an R for sale (picasso)
Thanks guys. Is a compression test necessary?? Wouldn't I be able to tell from driving the car if it has bad compression?? I would assume it would be down on power.
Another question then. The car has an aftermarket short shifter, Can this hurt the transmission?
Also one of you guys said it has a standard rear tower brace. I didn't see one, but it did have the rear trunk bar (on the rearmost section of the trunk above the jack.)
BTW: CW = Champ white (color)
Old Oct 30, 2002 | 12:42 PM
Dave-ROR's Avatar
No it's not. The rear hatch/"trunk"/whatever brace is standard, a rear tower/strut tower brace is not.
and yes, do a compression test. Unless you've driven a lot of ITRs there's not way you are going to be able to tell this one only has 200 compression, etc.
Old Oct 30, 2002 | 12:50 PM
.Chris.'s Avatar
Default Re: Hey guys, Couple questions about an R for sale (Dave-ROR)
I suppose this means that without the right tools ill be heading down to a dealership.
BTW, are the C5's more prone to loose compression than a C1??
Old Oct 30, 2002 | 12:56 PM
Dave-ROR's Avatar
no.
and a compression tester is like 20-25 bucks at discount/sears/etc
Old Oct 30, 2002 | 01:03 PM
RockstarJR's Avatar
Make an appointment and take it to Honda/Acura... It is fairly cheap when considering the headaches you could be facing in the future. Don't be stupid... I learned my lesson the hard way.
Old Oct 30, 2002 | 01:13 PM
Dave-ROR's Avatar
Default Re: Hey guys, Couple questions about an R for sale (ITRChris)
ITRChris: you're in tampa? hmm did you buy the car locally and got screwed? private owner?
jaminc
Texas -OK -LA (Sales)
11
Dec 20, 2009 08:34 AM
truevietluv636
May 16, 2007 08:09 PM
92hatchy_7
Feb 20, 2005 11:19 PM
lilxvtecxpwr
Sep 22, 2002 05:54 PM
