Missfire on open throttle
Old Mar 22, 2014 | 06:41 PM
MTBR27's Avatar
Default Missfire on open throttle
Hey guys, I have a issue with my d16y8 M/T, every time I would give the car more gas the car has this pow! sound on all four cylinders around 5k rpm and it reduces horsepower. I done a compression test and cylinder leak down test and they all pass (higher spec rating). I checked to see if I was getting enough air into the engine and same with fuel and spark and it was. I have 2 inch headers to 2.5inch piping all the way and a open cold air filter (k&n). I think I could have a bad EGR valve but I want to see if anyone else had or is having this issue too, please help! Thanks!
Old Mar 22, 2014 | 08:24 PM
mtber's Avatar
Default Re: Missfire on open throttle
If your check engine light is on, check your malfunction indication codes & resolve them.
http://phearable.net/information/check-codes.html
Old Mar 22, 2014 | 09:55 PM
Muckman's Avatar
Moderator in Chief
When was the last time you did any general maintenance - Spark plugs, plug wires, cap & rotor, fuel filter etc?
Old Mar 24, 2014 | 03:39 AM
MTBR27's Avatar
There's no check engine light on and no codes. I changed the fuel filter a few months ago, but plugs, wires and anything to do with the distributor haven't replaced it. I used a ohm meter to see if there's power going into the plugs and there is. Also thanks for the replys!
Alexander Smets
Jul 26, 2019 06:50 PM
Tucker33
Dec 16, 2013 09:40 AM
Meraut
Jul 29, 2013 09:00 AM
barkwaffle
Jun 2, 2005 10:09 AM
mickey513
Apr 7, 2003 10:30 AM
