need help with electrical issue
Old Oct 29, 2002 | 03:51 PM
accordfan's Avatar
Default need help with electrical issue
sorry this may be long. my distributor went out on me a week ago. while the car was down i bypassed the fast idle valve and the intake was ported. got everything put back together and the car idles fine and will rev to redline. as soon as you try to put it in gear and go it starts bucking and the tach needle jumps and the car just refuses to go. theres no check engine light. i have stumped 2 of my mechanics so i m coming to you all here. any help is apprecieated.thanks in advance.---joe
Old Oct 29, 2002 | 04:17 PM
Hondasaurs's Avatar
Default Re: need help with electrical issue (accordfan)
Possible the ignitor which is located inside the distrubuter. Also check your rotor and make sure its not loose.
Old Oct 29, 2002 | 06:13 PM
accordfan's Avatar
Default Re: need help with electrical issue (ZC_CRX)
new remanuf dist put on today rotor looked good.the tach needle jumps around too if that helps
Old Oct 30, 2002 | 04:50 AM
Hondasaurs's Avatar
Do you have an aftermarket tach? usually a bouncing tach is a sign of a bad distributer. Make sure you check all of your connections to the distributer. Look for any lose or frayed wires too.
Old Oct 30, 2002 | 11:44 AM
PnX-R's Avatar
Hmm... My stab in the dark would have to be Ignition Timing or the Ignition System is not getting enough current..
If the system isn't getting enough current, it can cause the engine to not let the car run above a certain speed and other weird problems..
WhiteGsrBeater
Jan 21, 2008 01:08 AM
Turbo_TONY
Mar 21, 2007 08:46 PM
decible01
Oct 12, 2006 01:53 PM
LSegHatchy
17
Jul 26, 2004 04:21 AM
murphymiddlesboro
Jun 27, 2004 12:46 AM
