catalytic converter bad?
Old Mar 22, 2014 | 11:37 AM
shpbling's Avatar
Icon6 catalytic converter bad?
98 Honda Civic DX 1.6ltr. Check engine light on, code reads need new catalytic converter. Is it possible that the after cat sensor is bad, not the converter?
Old Mar 22, 2014 | 12:03 PM
Dontoh's Avatar
Default Re: catalytic converter
What's the code that you're getting?
The best way to diagnose O2 sensors and catalytic converters is too hook your car up to a DSO or even a laptop based scan tool so that you can watch the O2 sensors feedback.
To answer your question- Yes, there is a chance that it could just be a bad O2 sensors, however unless its been tampered with, I personally doubt it. If your O2 sensors is reading poorly, there is also a good chance that your cat could be bad as well.
My recommendation would be to first, diagnose the issue. Second, replace what needs to be replaced. Finally, FIND THE CAUSE. Just replacing the parts isn't going to fix the issue, you need to figure out why they went bad. One thing to understand is that CATALYTIC CONVERTERS DO NOT GO BAD. They will last the lifetime of a vehicle easily, however there things that kill the cat. A coolant leak, a rich/lean condition. This is what you will need to find if the cat is bad, or you'll be replacing cats over and over.
This graph shows the difference between a good cat and a bad cat.
The blue is your upstream O2 sensors, reading rich, lean, rich, lean- going into your cat. The red is the same reading from the downstream O2 sensors, which tells us that the cat is not working properly
Old Mar 25, 2014 | 03:24 PM
shpbling's Avatar
Thanks for the input. I was going to replace both sensors anyway, when/if I replaced the cat. If it's the cats that bad, and I put in a new sensor, will it damage it?
Old Mar 25, 2014 | 06:45 PM
VegasInvasion's Avatar
I'm Huge In Japan
nope.
Old Mar 26, 2014 | 06:29 PM
hybridmiklo's Avatar
Default Re: catalytic converter bad?
Thats retarted to replace both o2 sensors and the cat just for the code. Either you get a decent scan tool so you can monitor the cat or take it some where.
Bleakened
21
Jun 25, 2014 05:48 PM
95_Civic_4dr
20
Nov 4, 2010 11:24 AM
96WhiteOnBlack
Feb 11, 2008 02:55 AM
sickofitall1113
Jun 11, 2007 10:20 AM
dayaftertomorrow
Apr 24, 2005 03:00 PM
