Honda prelude brake light
My honda prelude right brake light won't come on I switched my bulb with a light I knew worked and still nothing and I put my old bulb in the reverse light and it popped right on
check the inner contact on the bulb socket, push it in wiggle it, if nothing check for voltage by multi meter and just touch the pins on the socket wires
Since you have finally mentioned that this car was in an accident in another thread, it is highly possible that the harness has been damaged somewhere. You are going to have to trace wires and see what happened, or just replace that entire harness with a good donor harness from a junkyard etc.
HA0LEFIED
Nov 28, 2008 12:55 PM
