How do you remove the rear seats?
Old Oct 29, 2002 | 03:21 PM
RAF LTD.'s Avatar
Default How do you remove the rear seats?
Like the topic says, how do you get the whole assembly out?
Old Oct 29, 2002 | 03:42 PM
teg92's Avatar
Default Re: How do you remove the rear seats? (RAF LTD.)
which generation?
what year?
4 door 2 door?
Old Oct 29, 2002 | 03:46 PM
RAF LTD.'s Avatar
Default Re: How do you remove the rear seats? (teg92)
whoops sorry, 94 GSR 2 door
Old Oct 29, 2002 | 03:52 PM
badnan's Avatar
fold seats over. pull off carpeting (held down by about a total of 8-10 pin thingies. after that theres a 10mm socket right between seat and trunk.
thats all i can remember
i do remember that at my solo2 event i broke my 10mm socket and the broken part sliced my hand up pretty damn good and i was running around looking for something to stop the beelding, before it was my turn to run. ended up using masking tape and those wrist bands they give you when you enter. atleast i didnt get blood on my steering wheel
Old Oct 29, 2002 | 03:55 PM
RAF LTD.'s Avatar
Default Re: How do you remove the rear seats? (badnan)
anyone know the rest?
Old Oct 29, 2002 | 05:34 PM
Integra21's Avatar
okay - to remove the backs of the seats there is a clip thing that you have to pull off of each seat on the outside bottom corner. and then you just have to push it in to get it off of the other side - then they come right out -
for the bottom - you have to unbolt the bolt in the center - and you just have to play with the seat - tilting it forward. if you look you will see a metal that twists like crazy - just work at that for a while and youll be fine -
i did it in like 15 min. without even knowing what to do - its really not that hard
well i hope that helps
Old Oct 29, 2002 | 05:37 PM
RAF LTD.'s Avatar
Default Re: How do you remove the rear seats? (Integra21)
do you have any pix of how it looks without the seats?
sethrd
Honda Civic (2001 - 2005)
Aug 27, 2008 09:27 PM
Fuster_Cluck
Dec 16, 2002 09:33 PM
.Ryan
May 10, 2002 04:55 PM
JL 74
Mar 25, 2002 08:30 PM
daniel89civ
Mar 13, 2002 05:11 PM
