Putting head back together, need help ID'ing vtec orings and where they go!
Old Mar 19, 2014 | 09:58 PM
omiehomie's Avatar
Default Putting head back together, need help ID'ing vtec orings and where they go!
hey everyone, im putting back together a b series motor and figured this would be the best place to ask.
head was rebuilt etc and i think the machine shop managed to lose the center dowel + oring
i have snaps of my motor before machine shop and after machine shop.
i tried to hunt down on the interwebs what was missing.
here are my questions, and any help is appreciated.
1) i know the center dowel + o ring is missing. are they #23 in this part diagram?
http://www.acuraoemparts.com/delray/...All&vinsrch=no
2) the oil control orifices by the cam gear end of the head, does one get an o ring and the other does not? im confused on which gets an o ring. one of the orifices protrudes out and can host an o ring while the other orifice (closer to intake manifold) is recessed in and cannot accommodate an o ring?
3) is it correct to say the protruding oil control orifice gets and o ring and the one closer to the IM doesn't get one?
im attaching pics of my head pre and post. the pre pic was lousy and i could not make out the info that i needed. any wisdom is appreciated.
here is a pic i found from endyne:
my head POST:
Any Help is Appreciated :-D thank you and god bless anyone that helps turbo car come back to life
Old Mar 21, 2014 | 07:01 AM
donut.'s Avatar
Default Re: Putting head back together, need help ID'ing vtec orings and where they go!
I'll help.
1. Part numbers for the o ring and dowel under the middle cam cap are:
94301-08100 pin, dowel (8x10)
91302-GE0-000 o-ring (8.8x1.9)
2. Both orifices, intake and exhaust side have an O-ring. Its not only a orifice but a pin to lock the rocker shaft in place. Thread an 8mm bolt into it and pull it out to replace the O-rings.
91306-PJ4-000 o-ring (6.8x1.9)
3. No, see #2
4. That is way too much assembly lube
Old Mar 30, 2014 | 11:55 AM
omiehomie's Avatar
Originally Posted by donut.
I'll help.
3. No, see #2
thank you bro for your help and kindness to respond! i got it sorted out and it was identical to what you had explained too.
god bless you and your family for your help :-)
EG6_978
Nov 19, 2009 06:03 PM
Chrys007
Jun 26, 2007 01:50 PM
h22powered
Feb 2, 2004 01:13 PM
h22powered
Jan 7, 2004 03:51 PM
snake01
Jul 13, 2003 11:08 PM
