Timing belt - which seals to change
Old Mar 19, 2014 | 05:44 PM
kenzo42's Avatar
Default Timing belt - which seals to change
95 Accord EX - 205,000 miles on the clock.
I know the camshaft seal and crank seal, but:
1) What about balancer seals? Is there a front AND a rear seal you change?
2) When do oil pumps get replaced?
Thanks.
Old Mar 19, 2014 | 06:53 PM
djkurious's Avatar
Default Re: Timing belt - which seals to change
Balance shaft seal with retainer should also be replaced. Replace oil pump when they go bad. I have 412k on original oil pump and shows no signs of going bad.
Old Mar 20, 2014 | 03:51 AM
holmesnmanny's Avatar
The front shaft will have a seal the rear will have an oring and obviously the crank has the crank seal. Crank seal and oil pump seal are the same thing.
Odds are the front shaft will already have the retainer, if not get one from the dealer. It's a recall part that should have already been recalled and installed. It holds the front shaft seal in so it doesn't pop out.
Ajsbored
Apr 14, 2014 06:59 PM
1SickEG
Jan 28, 2013 03:54 PM
chock
Apr 13, 2008 09:24 PM
soon2bdropped
Apr 16, 2007 12:01 AM
pootie.teng
12
Mar 22, 2007 09:09 AM
