95 civic coupe ex vtec 3/19/14
Decided to part out my 95 civic coupe clean title tags until August 2014
I bought the car cheap from a friend and I was going to fix it up but plans changed and just selling everything. I dumped about $800 dollars in parts so the aftermarket stuff you see have only been on about 2 weeks
Selling the car in parts as I will make more money like that,time consuming but worth it so hit me u with the parts you need.
Here's a short list on some parts I've priced,anything you don't see just let me know and I will get back to you
OEM sohc d16z6 headers clean no cracks or dings. Comes with fresh working oxygen sensor $60
Blackies with hubcaps $100 (2) tires are 185/60/r14 (2) tires are 185/65/r14
Ignition switch & cylinder w/ door,trunk cylinders and 1 key,comes with vin plate so you can make a fresh new key if even possible but will come with it anyway. ***SOLD***
Optima battery just got it about 6-8 months ago and was on a car that was driven about 3-5 times a week $100 still has prorated warranty
95 civic shell w/ title ***SOLD***
95 civic ex with vtec obd1 Engine harness complete no cuts or tears perfect working condition***SOLD***
Black semi new Beaks bar was installed only clean no scratches $60
Sick bar subframe, installed and only used for a week never driven with it on $65
Semi new Neo Lca installed and drove about 50 miles still just like new removable bushings $80
Engine w/ trans aprox 130-150k miles runs perfect absolutely no problems no leaks I will let you test drive the car if still possible to make sure there are no problems.
Comes with engine,trans,axles,starter,dizzy,alt,mounts and linkage $700 (ENGINE SOlD) ***SOLD***
Transmission, semi new axles and semi new starter and T bracket all in perfect condition no grinds or kick outs No "BEARING" noises when clutch is pressed in $325***SOLD***
P28 ecu 5 speed manual vtec ready virgin $100 ***SOLD***
Ac setup complete engine bay only, compressor,belt,lines and condenser and fan$100 ***SOLD***
Power steering pump and belt,brackets $50
Radiator w/fan and hoses $60
Both fenders new reps only mounted no dings $75
Call or text 562 533 5076 pickup in Garden Grove 714
Just pulled the engine out , engine is sold.
Engine harness complete no cuts or tears, a little greasy but in perfect condition no broken plugs $100
Still have the trans, and complete conversion for auto to manual****SOLD****
Trans sold
Starter sold
Trans mount sold
Clutch line sold
Trans sold
Starter sold
Trans mount sold
Clutch line sold
Complete ac setup(parts still in car) lines,cond,comp,belt,bracket,fan. $100
Radiator,fan and hoses,overflow tank ,all in good condition works perfect. $50
Baddass mop and bucket, Not for sale....
D16z6 ex Transmission smooth trans no grinds or kick outs $250****SOLD****
Both axles good condition $50 set
Starter $25
T bracket $30
Trans mount $25
Or take all for $325
Power steering pump W/ Res and bracket/ belts $40
Starter $25
T bracket $30
Trans mount $25
