b16 with itr style IM and boltons looking for crome bin
Old Mar 19, 2014 | 02:01 PM
raverx3m's Avatar
Default b16 with itr style IM and boltons looking for crome bin
anyone can share a bin file?
i dont have crome pro or wideband for it but it will be still better than using stock p30basemap.
i have stock b16 with AEBS intake manifold, ebay 4-2-1 header and 2.25 catback with ebay short ram.
Old Mar 19, 2014 | 02:49 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: b16 with itr style IM and boltons looking for crome bin
Not really as you don't have much done to it at all. Unless you are wanting it to just run rich, stick the the P30 basemap as it already has built in cushion for a PR3 engine.
Old Mar 19, 2014 | 09:02 PM
raverx3m's Avatar
i dont think stock maps make up for all that. like many people said here. even after boltons most of them run on a leaner side
Old Mar 20, 2014 | 06:50 AM
Freemananana's Avatar
I have 'bolt ons' and such on my car. When I floor it with the stock P30 map it still pegs 12~13 AFRs on my wideband. During cruise it will stick at 16-17 but that's fine.
This isn't the best suggestion. But if you have a bin, why not just add a small amount of fuel if you are worried about being lean? Also, there are a lot of crome bins of people with bolt ons and such, you can try those.
Xenecron's link:
http://www.xenocron.com/bins/index.p...Crome/B-Series
B16 with I/H/E, 12-13 WOT AFR:
http://www.xenocron.com/bins/index.p...rome/B-Series&
Old Mar 20, 2014 | 09:32 AM
raverx3m's Avatar
Thats the only one I found so far. Im just gonna take the wideband out of my del sol and do a street tune as good as i can
with a stock b16 is it possible to use knock sensor when tuning the ignition?
I have a p30 with knock bboard
Old Mar 20, 2014 | 01:24 PM
DO IT ON ALL FOURS
Interesting because I had every N/A bolt on you can have and my AFRs were low 15s cruising - then again this was a OBD-0 B16A so I guess I could see it being slightly leaner. The WOT portion is very rich on the stock map though.
In my experience with CROME and the stock map knock sensor it is a PITA as it gives a lot of false readings and is extremely sensitive. No matter what you should be pulling plugs to verify one way or another even if you have the knock board.
Old Mar 20, 2014 | 01:40 PM
raverx3m's Avatar
i suck at reading plugs
heres them pulled at idle it was failing also
Old Mar 20, 2014 | 04:49 PM
VegasInvasion's Avatar
I'm Huge In Japan
they look rich. but I can't see the anodes which is usually where knock is detected so I can't really confirm safety. there are many threads on reading plugs, you should spend a bit of time looking through them.
Old Mar 20, 2014 | 07:17 PM
DO IT ON ALL FOURS
They look pretty wet for idle... you need to get a wideband on the car.
Old Mar 20, 2014 | 09:31 PM
raverx3m's Avatar
theres a bit of oil from the plug holes.
cyl 1 and 2 are lighter than cyl 3 and 4 not sure what that would mean
Old Mar 20, 2014 | 09:32 PM
raverx3m's Avatar
you can zoom in the picture click and there will be zoom icon in right bottom corner
Old Mar 21, 2014 | 05:44 AM
DO IT ON ALL FOURS
I have zoom, your pictures are too blurry to get and useful porcelain readings. When you uses a magnifying glass to check them.... the pics need to be perfect with good lighting.
b16eh2
Nov 10, 2014 07:48 AM
TheLegendRGS
Dec 12, 2007 10:46 AM
honda06si
Aug 26, 2004 07:53 PM
kun3racer
Jan 28, 2004 03:48 AM
