B series CRX - Axle / Trans question. (detailed)
Old Mar 19, 2014 | 10:49 AM
ThaEfSwap's Avatar
Default B series CRX - Axle / Trans question. (detailed)
Hi I need help with my CRX. I've done alot of searching.
I have a B18A1 from a 1992 Integra, with a B16 cable transmission (Ys1) from a 1992-1993 Integra from Japan. That transmission blew, and I now have a Y1 transmission lying there, which is a 1990 to 1991 integra from Japan. I understand I have to change the clutch to 1990-1991. I have an intermediate shaft from an Integra GSR (1996) and an axle to match (1996 integra axle)
Will the Y1 transmission fit a 1990-1993 axle? And will the Y1 transmission fit the 1996 Integra GSR intermediate shaft? That's all I need to know.
Old Mar 19, 2014 | 11:07 AM
Freemananana's Avatar
Default Re: B series CRX - Axle / Trans question. (detailed)
All B series transmissions should be splined the same and accept all B series axles and half shafts. If your axles match the half shaft, you will be fine.
Most people use the 90-93 axles and half shaft. Make sure your axles work with the half shaft you have.
If you are just replacing the trans and the set up previously was working just fine, keep the same axles. They will swap right over.
Old Mar 19, 2014 | 12:23 PM
ThaEfSwap's Avatar
Alright, so the 90-93 axles will work on the 90-91 transmission, now what about the intermediate shaft?
I have doubts the integra GSR intermediate shaft will fit into the 1990-1991 Y1 transmission.... It's a 97 GSR intermediate shaft.
Old Mar 19, 2014 | 12:40 PM
It fits. You need the 90-93 half shaft for the 90-93 axles. You need the 94-00 axle for 94-00 half shaft.
Old Mar 19, 2014 | 12:47 PM
91 EF DX's Avatar
Also dont forget to match the correct axle seals on the trans with the axles.
Old Mar 19, 2014 | 12:49 PM
ThaEfSwap's Avatar
My old setup is 1996 GSR integra intermediate shaft, with a 94+ axle seal and 94+ axle for the driver side, with a 92-93 YS1 transmission, with a 92-93 Axle for the passenger side.
All I want to do is change to the Y1 (90-91) transmission. Do I need to change my intermediate shaft from the GSR to the older one, or no? Few hours away until I take it off and check
Old Mar 19, 2014 | 12:50 PM
91 EF DX's Avatar
No just change the axle seal
Old Mar 19, 2014 | 12:55 PM
ThaEfSwap's Avatar
Are the 90-93 axle seals the same? I have the 94 axle seal to match the intermediate shaft for the driverside, so I can re-use my old axle (1992-1993) with a new 1992-1993 axle seal for the passenger side.
Old Mar 19, 2014 | 01:20 PM
maddix's Avatar
My setup: axels from Honda Orthia'00 b20 at, intermediate shaft spec 98, seal spec 98, tyranny y1
Old Mar 19, 2014 | 02:25 PM
Deetz's Avatar
Crazy Honda Guy
I'm just going to jump in and give an answer without reading other posts.
If you currently are running a YS1 larger spline tranny, and switching to a Y1 (which is older and not as good btw), you can reuse your existing intermediate shaft and axels. As far as the clutch goes, the smaller mainshaft design found in 90-91 b series tranny's needs a different clutch disk....the pressure plate should be the same and work fine
Old Mar 19, 2014 | 02:31 PM
ThaEfSwap's Avatar
Thanks Deetz, I'm getting the trans for 240 dollars, I can't say no. I got a free clutch for the year 1990-1991 B series, so all in all 240 dollars for the trans swap.....
answered my question, thank you.
2x0
16
Sep 21, 2017 05:13 AM
jdmjackson
Feb 14, 2013 03:52 PM
rdeezy78
May 8, 2009 01:47 AM
EK_vzla
Nov 12, 2007 10:35 AM
nexgen91
Mar 26, 2006 08:44 AM
