(GSR?) brake pads (pics)
Old Mar 19, 2014 | 08:58 AM
hwyix's Avatar
Default (GSR?) brake pads (pics)
I purchased 93 hatch with a gsr engine. The PO told me it had had gsr rotor and calibers. The GSR rotors I bought fit fine but the GSR brake pads do not.
full size photos here.
http://www.flickr.com/photos/9223597...7642598783343/
Old Mar 19, 2014 | 09:17 AM
B_Swapped93's Avatar
Default Re: help identify brake pad please (pics)
I'm assuming the old pad was the one that was on there ? they seem the same size but the little guide that it slides in the caliper on is different, what brand are they AK seems like a no name.
Old Mar 19, 2014 | 10:16 AM
delsolo95's Avatar
give us the number stamped on the caliper. you may have an civic ex ek caliper/rotor since rotors are same size as gsr
Old Mar 19, 2014 | 11:27 AM
hwyix's Avatar
Stamped on the caliper in four different places is:
ORG
LG
2210
5410
Do you want a a pict?
Old Mar 19, 2014 | 11:29 AM
hwyix's Avatar
I purchased the new pads through a friends auto shop. He ordered them through worldpac.
akebono brake pads as274h GG
Old Mar 19, 2014 | 11:36 AM
delsolo95's Avatar
the caliper, if gsr or any 94-01 (excluding type r) should be stamped 17CL14VN
hwyix's Avatar
Old Mar 19, 2014 | 11:37 AM
delsolo95's Avatar
i would bring the old pad to an autozone or auto parts store and have them check out civic various yrs including yrs with abs for brake pad similarities
Old Mar 19, 2014 | 11:39 AM
delsolo95's Avatar
Originally Posted by hwyix
can you get another view from the front of the caliper?
Old Mar 19, 2014 | 11:47 AM
delsolo95's Avatar
should be like (not my photo) this
Old Mar 19, 2014 | 12:02 PM
hwyix's Avatar
Thx everybody. When I get back home I will take a new photo.
Old Mar 19, 2014 | 12:05 PM
hwyix's Avatar
good idea. I would like to narrow it down if at all possible to say 2 or 3 choices. If I ask him to show me all the brake pads for civics/integras I think they are going to show me the door.
My car does NOT have abs. Sorry I did not mention that.
Old Mar 19, 2014 | 01:03 PM
delsolo95's Avatar
my car wasnt equipped with abs either but i have brake master cylinder and brake calipers from and integra that did.
here is a list i grabbed from username- 94eg!
Integra NON ABS setup:
- 17CL14VN calipers w/ larger piston
- Larger/cheaper brake pads
- 10.2" rotors
- 15/16" Master cylinder
Integra ABS setup:
- 10.2" rotors
- 1" Master cylinder
92-00 Civic/Sol w/ big front brakes NON-ABS (92-00 EX, 99-00 Si, 94+ VTEC)
- 16CL14VN calipers w/ smaller piston
- Smaller more expensive brake pads
- 10.2" rotors
- 7/8" master cylinder
92-00 Civic/Sol with ABS:
- 17CL14VN calipers with larger piston
- larger cheaper brake pads
- 10.2" rotors
- 1" master cylinder
91 Civic EX Sedan NON ABS:
- 17CL14VN calipers w/ larger pistons
- larger/cheaper brake pads
- 10.2" rotors
after some pic ref it look like you have these regular civic ex with non abs
Old Mar 19, 2014 | 01:33 PM
delsolo95's Avatar
or these 99 civic ex
im leaning more towards these cuz 99 civic uses the same size rotor as integras
Old Mar 19, 2014 | 03:31 PM
hwyix's Avatar
My car does not have any numbers there or the PO sanded it down and painted over with some flaky read paint and I can no longer find the number.
Old Mar 19, 2014 | 03:32 PM
hwyix's Avatar
Thank you everybody. With your guys help I was able to narrow it down to a
1999 Civic EX 2 door coupe.
NOT GSR
My receipt says pfc 0465.21
If you look at the pfc website it "looks like" my pads are used on a lot of honda/acura.
http://www.pfcbrakes.com.au/pad_details.php?id=0537
Old Mar 19, 2014 | 03:35 PM
hwyix's Avatar
thanks for the extra info Delsol95 on brake up grades in post #13.
https://honda-tech.com/forums/showpo...3&postcount=13
My car had a spongy pedal. I just upgrade my master cylnder before my track event to
15/16th. What PITA to find. hahaha. My brakes still are not as good as I would like them
for the track. I guess I will have to save up for some aftermarket brakes.
Old Mar 20, 2014 | 08:02 AM
delsolo95's Avatar
your welcome. glad we could help. try upgrading to stainless steel brake lines and use motul brake fluid. btw im pretty sure you have aftermarket calipers that you can buy at autozone, o'riellys, etc
Old Mar 20, 2014 | 08:31 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Sounds like you need to bleed the lines a few times. It took 3-4 after i did my caliper swap to get a nice pedal feel.
donut.
Jun 5, 2008 08:43 AM
YNOT
Oct 29, 2002 08:20 AM
eg_nezay
Mar 7, 2002 07:26 AM
