Transmission & Drivetrain Gearboxes, Differentials, Clutches
B16A Y21 transmission
Old Mar 19, 2014 | 12:02 AM
danrsx's Avatar
Default B16A Y21 transmission
Can anyone tell me if this is a USDM or JDM transmission? Did it come with a factory LSD? I can't check since it is installed on my vehicle. Thanks!
Old Mar 19, 2014 | 08:05 AM
David @ Synchrotech's Avatar
Default Re: B16A Y21 transmission
It could be either one. The Y21 was used in the 1994-1995 USDM Del Sol without LSD and also in the JDM B16 transmissions with Viscous 14 bolt LSD and without LSD. If you pull the axles and look inside you will see a diff pin for the open diff or straight through (no pin) for the LSD model.
Old Mar 19, 2014 | 09:34 AM
danrsx's Avatar
Thanks for the info!
shaylude01
Jan 19, 2011 06:10 PM
dragaholic
Jan 20, 2006 05:48 PM
CR-V-tech
Oct 29, 2003 05:37 AM
oMek
Aug 24, 2003 09:26 AM
