Funny idle after I revved my motor
Old Mar 18, 2014 | 04:16 AM
snoopaloop986's Avatar
Default Funny idle after I revved my motor
I just had a cat back installed on my 92 lude it's the f22 and was showing it off this morning to a buddy and now it's idling funny almost like it's going to die I shut it off before it actually did if anybody knows anything please help me at
Old Mar 18, 2014 | 04:52 AM
holmesnmanny's Avatar
check your mechanical timing if u revved it hard
Old Mar 25, 2014 | 12:52 PM
Default Re: Funny idle after I revved my motor
After I let it sit all day after work got in started up and drove fine seems to be idling right now I do have another issue though after driving awhile at like 50 and above when I come to a stop it makes a whiny almost whistle sound when decelerating it does it a lot but not every time I stop I cannot pin point the sound
Old Mar 25, 2014 | 01:44 PM
Sparksman's Avatar
Might as well check ignition timing, for vacuum leaks, and the TPS.
Old Mar 25, 2014 | 01:46 PM
Hawnduh_Ownr's Avatar
When you say you were revving it, and showing off, do you mean like a real Honda owner bouncing off the limiter, etc?
Old Mar 26, 2014 | 08:30 AM
No I've never hit the limiter on it I've always worried that would tear it up am I right?
Old Mar 26, 2014 | 10:06 AM
GSR_BUM's Avatar
vacuum line may have came loose or may be faulty. or maybe IACV could be intermitting. my LS-V did that before, it would idle smooth, then when i gun it, it would idle funny lol. then after a bit it would be normal again.
Old Mar 26, 2014 | 10:58 AM
crazyhouse2011's Avatar
Naw, hitting the limiter is like seat belts in a crash.
Don't hit it all the time, but in theory the limiter is there to PREVENT damage to the engine. So a few bounces now and then to show the ladies what you're rollin' won't hurt anything.
Old Mar 26, 2014 | 10:59 AM
I ordered a set of plugs wires cap rotor timing belt water pump see if that helps
Old Mar 26, 2014 | 12:21 PM
Ok thanks I'm not Rollin much but I'm still proud to be rolling a honda I have plans to build it up a lot more than it is but for now I'm gonna try to get everything on it squared off I just rolled 200k so I need to replace the timing belt right? Also will that improve any performance?
Old Mar 26, 2014 | 07:21 PM
Old Mar 27, 2014 | 10:32 AM
Lugzilla's Avatar
Canuckian
None whatsoever. Will stop your heart from breaking though if the old belt snaps and fubars the motor.
Nick Comstock
Sep 5, 2022 02:14 PM
NoVALude
Nov 20, 2006 11:02 AM
lshatch92
21
Oct 28, 2005 06:38 PM
Fullthrottlegsr
Jul 16, 2004 09:05 PM
01PYTypeR#1140
Jul 17, 2001 07:05 AM
