MSD ?
Old Mar 17, 2014 | 06:23 PM
the red eg's Avatar
Default MSD ?
So tried to fire up my new build wouldn't start so I check for spark and found I have none. While going through the trouble shooting I found that the small red key hot wire from the box is only getting 10volts during cranking. How do I fix this issue
Old Mar 18, 2014 | 02:51 AM
non-VTEC's Avatar
Default Re: MSD ?
throw the MSD pile of **** into the trash and use a OEM distributor/coil setup.
ps. while cranking system voltage @ 10v is normal.
Old Mar 18, 2014 | 06:17 AM
smilindave's Avatar
Default Re: MSD ?
I agree, toss the pos msd box and go with what works. If you do your do research, you will find the msd units available to the public do not work. They do not have the ability to start and stop rapidly, so you end up with a constant on spark. I will not ever recommend their use. If you must spend money, change over to coil on plug units, otherwise go with what works. The tried and true oem.
Old Mar 19, 2014 | 09:29 AM
the red eg's Avatar
Default Re: MSD ?
I was having lots of blowout when getting in the revs on 360whp. Looked into COP but Hondata says it doesn't work with jdm ecu. Does anyone know if I need to cut and seal the green loop. With 82933 distributor
Old Mar 23, 2014 | 02:43 AM
non-VTEC's Avatar
Default Re: MSD ?
my setup made over 440whp using OEM distributor/coil/wires and ngk heat range 8 race plugs gapped to .030 for years. no spark issues.
Old Mar 23, 2014 | 04:37 AM
sirtef9's Avatar
Default Re: MSD ?
I've see a few issues with the MSD setups, ditch the crap and go oem.
si_motor_spt
Oct 29, 2020 09:54 AM
EJ8Squad919
Jun 16, 2012 11:41 AM
kornerk12
May 4, 2007 07:32 PM
EE_Chris
Apr 28, 2005 12:16 PM
