cold start problems? 94 accord
Old Mar 17, 2014 | 06:07 PM
Loughf's Avatar
Default cold start problems? 94 accord
This is a video of what it's doing. I have no idea. at the end, you see it idle for a second, but if I were to have give it gas, it would have bogged down and died. Once she's warm tho, she runs fine. But at cold start, every time.........This crap.
please take the time to look at the video. It's less than 1 minute. I'd really like to get this problem fixed. I just have no where or any other idea where to start.
Old Mar 17, 2014 | 06:26 PM
ej7attack's Avatar
Default Re: cold start problems? 94 accord
seeing as it would run with your foot on the gas perhaps you fitv is not functioning. I would say you have spark and fuel. next would be to check air control components.
also make sure your egr valve hasn't developed a leak.
Old Mar 17, 2014 | 06:57 PM
Loughf's Avatar
I don't have an egr. I was told it a an "egr delete"?
and I want to clean the IACV and FITV to stop the weird idle and sputtering at idle. just can't find time to do it right now. will that fix this cold start issue too?
Old Mar 17, 2014 | 07:10 PM
holmesnmanny's Avatar
test engine coolant temp sensor across the two pins for ohms .. should be 2000-2500 ohms when engine completely cold and 180-250 warmed up
Old Mar 18, 2014 | 05:42 AM
Loughf's Avatar
What will that do or solve? :/
Old Mar 18, 2014 | 03:30 PM
it will test if its bad or not
Old Mar 19, 2014 | 03:54 PM
ej7attack's Avatar
if the ect sees that the motor is warm when its not, it will send a false reading to the other sensors and ecu that rely on the ects info for correct idle at startup.
chikin pickle
Mar 22, 2010 09:54 PM
Mishima
Dec 10, 2009 04:55 PM
Elbowpunk
Nov 11, 2007 10:16 AM
bigrush2006
Feb 5, 2007 08:05 PM
seeodywhy
Sep 1, 2006 05:22 PM
