CSF sensor
Old Mar 17, 2014 | 12:55 PM
KidRuthless's Avatar
Default CSF sensor
I went to autozone pulled code P1337 CSF (Crankshaft position sensor) after looking mine is not plugged into the harness how would I wire it in to my harness? Also what will be some symptoms of it not being plugged in?
Engine: Obd2a GSR b18c1
Wireharness: 1997 Honda Dx HB
ECU: Stock p72
Old Mar 17, 2014 | 01:54 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: CSF sensor
Is your engines 2 wire and engine harness 3 wire?
https://honda-tech.com/forums/showth...5245&styleid=2
Old Mar 17, 2014 | 02:42 PM
Yes i found your link very helpful, unfortunately i cant locate the male plug on the harness? will there be symptoms if i do no plug this sensor in?
Old Mar 18, 2014 | 09:22 AM
Bump, anyone know where the male plug is on the harness for this sensor? Or if it has one?
Old Mar 19, 2014 | 01:07 AM
Technical Hero
It should be near the crank where it plugs in.
B18CivicEH2
Sep 10, 2007 07:10 PM
QuangAlang
Nov 30, 2006 11:25 PM
91civichatch
Apr 24, 2004 01:25 PM
NatedoggAZ
Nov 8, 2003 03:59 PM
HalifaxITR
Apr 11, 2002 07:27 AM
