whats my problem
Old Mar 17, 2014 | 08:46 AM
semibull's Avatar
Default whats my problem
hi i am new here. i have a 2000 accord lx coupe 2.3L. recently after a 30 min run on the highway, the motor would stall and die. after 10 min it would start and idle fine but once you hit the gas or put it in gear (automatic) it would die. After 45-60 min it would start and run fine. this went on for a few weeks. now it will start and die as i said before no matter how long its left.
the only code showing is a evap one, but thats been there awhile. i have replaced, oxygen sensor, map sensor, ect sensor, fuel pump, checked distributor, rotor, wires replaced plugs.......nothing seems to work.
could someone give me some direction to go in. thanks
Old Mar 17, 2014 | 10:42 AM
ej7attack's Avatar
Default Re: whats my problem
perhaps ignition swtich?
while your car is running jiggle the keys around. see if that causes it to die. then you know your problem. if it doesn't then its something else.
Old Mar 18, 2014 | 05:03 AM
semibull's Avatar
thanks i will try that. i was also wondering about the IACV, if i could clean that and see what happens.
Old Mar 18, 2014 | 01:21 PM
MAD_MIKE's Avatar
MM Gruppe B
Remove the gas cap. Does the car start?
Old Mar 25, 2014 | 04:36 AM
semibull's Avatar
well i am narrowing things down. i replaced the distributor, cap, and rotor button. this helped some, but the problem was still there. upon further inspection it was found that the previous owner that a fuel line replaced and that the evap was bypassed, thus causing some negative pressure in the gas tank. As i did not have a new evap system a work around was done on it. and so far its been working. It has stalled a few times, but has started up right away, with a strong fuel smell.......flooding. so now to try and correct this.
any ideas?
Old Apr 13, 2014 | 03:25 PM
semibull's Avatar
We'll still having same trouble. Cat was blocked , fixed that. Have no idea whats next as no codes showing
Old Apr 14, 2014 | 04:51 PM
ej7attack's Avatar
fuel filter or fuel pressure regulator maybe. test it and confirm its functioning. fuel pressure should decrease as intake vacuum increases.
C_Rock77
Feb 15, 2013 01:32 PM
HX35_Ek_Hatch
Jan 15, 2013 07:29 PM
kc_boss_816
13
Mar 8, 2009 08:34 PM
midwesta
Jan 27, 2008 02:32 PM
Poptart
Aug 25, 2006 03:27 PM
