Subframe question
Old Mar 17, 2014 | 07:06 AM
jmacsss's Avatar
Default Subframe question
I have to replace my subframe in a 98dx hatch due to rust. Car came with factory power steering and air conditioning. I have a 99ex parts car and I was wondering if the subframe will work and what master bushing kit I will have to use as I noticed they list a 96-98 and a 99-00. Any help is appreciated and I thank you in advanced.
Old Mar 17, 2014 | 09:19 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Subframe question
it will work fine.
bushing kit refers to what year control arms you have.
you can also fit an EG subframe in most do with kswaps (use eg control arms)
Old Mar 17, 2014 | 09:29 AM
Fliptard's Avatar
all 96-00 subframes are the same, if you use the subframe and control arms from the 99, get a kit for 99-00.
Old Mar 17, 2014 | 11:32 PM
BrakeExpert's Avatar
The 96-00 Civic EXs all have the same control arms, no idea why its listing two different years.
The bushing kit MIGHT be thinking specifically for the 99-00 Civic Si. The Si model uses an LCA like the CTR. Its a stamped piece with a wider bushing for the shock fork AND the back bushing (the one that bolts in/on) is firmer. That back bushing is interchangable to all 96-00 models tho.
Old Mar 18, 2014 | 03:29 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
^yes. The only different bushings are 99-00 Si.
Don't use poly bushings though.
axis11
Feb 24, 2014 04:44 AM
buck02
Dec 8, 2006 02:02 PM
s2k drifter
May 2, 2005 08:59 PM
