Honda CR-V & Element 2WD & 4WD Element & CR-V
CRV 2002 Stalls right after starting
Old Mar 17, 2014 | 02:57 AM
aymoushz's Avatar
Icon2 CRV 2002 Stalls right after starting
Hi Guys,
I have this problem with my car stalling right after starting, rpm drops to 0 then turns off, starts right back up then stalls...
I have already removed and cleaned the IAC, removed and cleaned the fuel pump, cleaned the Throttle Body.
The issue started with the car stalling when slowing down and braking, however, this has deteriorated into car not even idling.
your help and advise is much appreciated.
Thank you
Old Mar 21, 2014 | 06:45 AM
honvol's Avatar
Default Re: CRV 2002 Stalls right after starting
check that you have ignition! maybe the distributor is death.
Old Mar 21, 2014 | 08:41 PM
aymoushz's Avatar
Hi mate,
I cannot locate a distributor on this model and I was told there isnt one, I have checked for sparks on coils nothing, replaced them along with relays still no luck
Could someone advise whether this model has a distributor or not and of its location please.
Thanks
Old Mar 21, 2014 | 09:32 PM
Punkaddic's Avatar
fuel pump might be dying. check fuel pressure
Old Mar 22, 2014 | 03:25 AM
Jjbaehr's Avatar
Check your fast idle valve
Old May 17, 2014 | 03:31 PM
4-door Chevelle's Avatar
Where might the fast idle valve be?
VSG
Dec 17, 2008 12:42 PM
futurerel
Apr 24, 2005 07:30 PM
Malgerus
Aug 6, 2002 01:04 PM
IntegD
Feb 6, 2002 12:27 AM
