B18 head gasket issues
Old Mar 15, 2014 | 08:53 PM
JDMpadawan's Avatar
Icon2 B18 head gasket issues
ok ive got a b18a1 with a b18b1 head, ive done a full rebuild and the gasket kit I bought was for a b18a1. Got it started today and immediately started blowin thick white smoke out the tail pipe. Checked, and yup milk for oil.... My question is... will the b18a1 head gasket on the b1 head cause this?!?!
Old Mar 17, 2014 | 09:16 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: B18 head gasket issues
headgasket is the same for A1 and B1 ....did you get the wrong bore size???
cracked head? block?
Old Mar 18, 2014 | 12:27 PM
JDMpadawan's Avatar
neither are cracked the head is practicly brand new and we did a full visual inspection of the block when it was stripped down. everything looked good. honestly the only thing i can think of is i need to use the later model head gasket to match the head. similar yes but i can see differences between the two. i will double check to make sure the bore matches between the head and block. thanks rick.
MigsD16
Engine Machining & Assembly
Dec 17, 2016 05:17 PM
strike1545
May 24, 2010 10:42 AM
new_climber
12
Jan 13, 2009 09:08 AM
drmix
May 22, 2008 06:20 PM
john457
Jun 26, 2007 05:48 PM
