Can anyone help identifying my GSR front sway bar equipment..
Old Oct 29, 2002 | 01:49 PM
navin's Avatar
Default Can anyone help identifying my GSR front sway bar equipment..
Hey guys, I ordered a GSR front sway bar back from hybridautomotive/IAS and I was wondering if anyone had pics of the individual pieces, I just opened up the package which i ordered like 3 months ago!
"Everything needed to bolt a 24mm Type R / GSR swaybar onto your 92-95 Civic. Included: Front lower control arms, 24mm swaybar, endlinks, D brackets, bushings."
Ok so I can indentify the LCA's and sway bar, I'm not that dumb. But what do the d-brackets look like, are they the things that the bushings are on..??
And what do the endlinks look like, I have GSR REAR endlinks for my ITR rear sway bar, and the front endlinks look nothing like that - this is what my friend says my Front endlinks are..
thanks guys - I wish I had a digicam to take a pic..
Old Oct 29, 2002 | 02:32 PM
navin's Avatar
Default Re: Can anyone help identifying my GSR front sway bar equipment.. (navin)
to da top y0..
doc cortez where you at..
shawnhayes..
eRRR
Old Oct 29, 2002 | 03:41 PM
madman604's Avatar
and using and ITR bar is cheaper/better than a dedicated swaybar from say Neuspeed?
Old Oct 29, 2002 | 03:47 PM
fowler!'s Avatar
Default Re: Can anyone help identifying my GSR front sway bar equipment.. (Turbo E)
Does Neuspeed make a 24mm sway for the front?
Old Oct 29, 2002 | 03:49 PM
navin's Avatar
Default Re: Can anyone help identifying my GSR front sway bar equipment.. (fowler)
no clue..
this is a GSR/ITR front 24 mm
I have an ITR 22 mm in the rear waiting to be installed after the fronts..
i wish i had got the EX 22mm sway bar..
Old Oct 29, 2002 | 03:50 PM
fowler!'s Avatar
no clue..
No you don't. This set up will be perfect
Old Oct 29, 2002 | 04:11 PM
navin's Avatar
We'll have to see - if i get bored ill yank the front out
but I do need this question answered please - pictures wuld be ******* awesome!
Old Oct 29, 2002 | 04:49 PM
navin's Avatar
ok - well Im going to go study for a photo test and then goto sleep, just bumpn this jam before I hit the sack. Hopefully it will be answered then..
*hopefully*
Old Oct 29, 2002 | 05:04 PM
rob d's Avatar
The d-brackets should have the bushings in it. It goes around the bar. The end links should look different from the rears. Its hard to discribe. I have a 22mm front bar if you want to trade.
1EK1EG
Jan 31, 2006 02:15 PM
null.
Aug 7, 2004 12:03 PM
JMD
Jan 27, 2004 06:45 PM
V-Grip! Teknic73
Nov 12, 2002 05:02 PM
