93 Accord Auto shifting rough
Old Mar 14, 2014 | 07:15 PM
dejay2014's Avatar
Default 93 Accord Auto shifting rough
Aloha,
my 93 accord is shifting rough. i tried changing the tcu and changing the fluid (used the Honda Genuine DW-1 ) neither helped. any suggestions?
thanks, dj
Old Mar 14, 2014 | 09:10 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 93 Accord Auto shifting rough
Rough, how? Is it just a hard shift or erratic?
Any codes stored in the TCU?
Have you checked your engine and transmission mounts?
Old Mar 15, 2014 | 10:27 AM
dejay2014's Avatar
kind of clunky when shifting up or down. not smooth. no codes except for the egr #12. no i have not checked the mounts. not sure how to . thanks,
Old Mar 15, 2014 | 09:02 PM
MAD_MIKE's Avatar
MM Gruppe B
If the mounts are torn, broken, or the rear mount may have a faulty solenoid or may be leaking fluid. Check the front dogbone shaped mount. It is a limiter, if the rubber is torn or cracking the mount will no longer be able to prevent excessive engine movement. The rear mount if it no longer functions correctly will allow too much movement and not enough dampening. This is usually accompanied by a large clunk or hard shifting with a thump, most noticeable when cold and switching from R to D4.
Old Mar 15, 2014 | 10:45 PM
dejay2014's Avatar
ok, thanks, will check
Old Mar 20, 2014 | 04:21 PM
dejay2014's Avatar
The motor mounts look Ok to me. I attached a picture but not sure if I did it correctly.
When cleaning up after my mechanic changed the fluid I see he only used 2.5 quarts. I called him and he said that was all it would hold. He said he had it jacked up from the front to get it all out. Is that good? I checked the level today and it is full. I see where it should take 3.8 quarts.
Old Mar 20, 2014 | 07:30 PM
MAD_MIKE's Avatar
MM Gruppe B
You will need to look at the side of the mount. That mount is a 'dog bone' shape. #16
You will need to look at the side where those washers are to make sure the rubber is not broken/torn.
No. The car should either be level, or with the back up.
With the nose up the fluid can drain back towards the differential area.
I usually just stick a pan under the car and remove the bolt without jacking the car up. There is plenty of room, unless your car is lowered.
My 93 accord
Sep 21, 2015 03:07 PM
h22accordian
Nov 2, 2011 04:32 PM
Sargosailor
May 18, 2006 06:03 AM
CanuckCRX
Aug 19, 2003 07:19 AM
RastaGt1
May 20, 2003 09:49 AM
