Suspension & Brakes Theory, alignment, spring rates....
brake pads problem
Old Mar 14, 2014 | 06:53 PM
martin31's Avatar
Default brake pads problem
hi am a new owner for a 2001 honda civic ex and i recently tried to change my brake pads because the were worn out and the bottom bolt to remove the caliper was stuck and i tried to force the new brake pads in and it work but then it was too tight and when am on the road the rotor would heat up high so i took of the front brake pad and put the old one back on.. so the front is a used brake pad and the back is a brand new one... will this mess up my brake or is their a way i can loosen the bolt so i could put the other new pad on? its just for the front drivers side tire, the passenger side had no problems.. please help.. asap....
Old Mar 14, 2014 | 09:14 PM
redlinetuning's Avatar
Default Re: brake pads problem
take the caliper off and grease up your glide pins. Sounds like your pins are seized and the caliper isn't moving as it is supposed to. You may need to take a wrench and hold the pin in place while turning the bolt.
Once the caliper is off and cleaned, push your brake piston in with a c-clamp and your new pads should fit fine.
Old Mar 14, 2014 | 10:25 PM
slowcivic2k's Avatar
Replace the caliper bracket, as the pins do not function. I suppose if you want to put labor in to it, you could grind the rust off. Not worth in in my professional opinion.
Old Mar 15, 2014 | 05:26 AM
martin31's Avatar
i see.. i'll just replace my caliper bracket... thanks.. much appreciated..
h8ted ek
Aug 26, 2008 04:18 AM
Import_spoon
Oct 23, 2006 03:25 PM
athoughts
Nov 17, 2005 03:12 PM
aziz93
Nov 25, 2003 06:25 AM
Fooman
Nov 26, 2001 09:26 AM
