Oil Pan Bolt Torque 120 in/lbs really?
Old Mar 13, 2014 | 09:29 AM
cfiiman's Avatar
Default Oil Pan Bolt Torque 120 in/lbs really?
I'm in the middle of putting my new gasket on and am to the torquing sequence and my manual calls 120 in/lbs or about 10 ft/lbs. This seems like a lot to me because I'm at 60 in/lbs now and it feels pretty dang tight. Any guidance info is appreciated, thanks.
Old Mar 13, 2014 | 09:52 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Oil Pan Bolt Torque 120 in/lbs really?
Is this for your 1978 Volkswagen Scirocco???
Old Mar 13, 2014 | 10:00 AM
cfiiman's Avatar
Sorry, 1998 Accord EX 2.3. I'm just worried about going to much more b/c the gasket is just starting to push out in a couple spots at 60 in/lbs.
Old Mar 13, 2014 | 10:24 AM
djkurious's Avatar
This gasket is a strange one and I know what you are talking about. At 10ft/lb it starts to push the gasket out like it is too much. I use between 8-9ft/lb and just watch as I tighten it and go from there.
Old Mar 13, 2014 | 01:27 PM
cfiiman's Avatar
Well I'm at 60in/lbs now which is about 5ft/lbs, would it be too risky to leave it at that setting and see? Can you always "tighten" it later if need be or is a one shot deal either way? I guess I could go up on the torque just a little nervous sense it is already squeezing some at 60 in/lbs.
Old Mar 13, 2014 | 03:53 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
My service information says the torque is 8.7 ft lbs
Old Mar 13, 2014 | 05:16 PM
bgdriver's Avatar
aftermarket gaskets without the metal reinforcements around the bolt holes will require less torque than oem and will split if you torque them to oem spec. Been there, done that.
Old Mar 13, 2014 | 06:40 PM
cfiiman's Avatar
Well this is confirmation of why I stopped at 60 in/lbs. even though it feels "tight enough" to me with the hand test choked up on the 1/4 drive I can't help but think maybe I should go a bit more anyone else have any thoughts?
Old Mar 13, 2014 | 07:13 PM
holmesnmanny's Avatar
start with middle bolts and go outwards towards the corners and you will be fine .. u can put a tiny dab of rtv on each bolt to help them stick and not back out over time .. if you make sure there is absolutely no oil on all surfaces it wont leak and you only need to snug the bolts and the four nuts
if there is any oil of any kind whatsoever count on it leaking
if there is hondabond on the block or pan use a razor to scrape it off... it needs to be flat with no leftover hondabond/rtv
hYbRid_Eg6
Feb 12, 2012 06:14 PM
93delsoldrew
Jun 22, 2008 09:38 AM
iheartintegras
Jan 21, 2007 12:42 PM
firewalkerr
Feb 13, 2006 05:56 AM
ILOVEGIRLS
Dec 17, 2001 09:53 AM
