Tranny wont go into gear
Old Oct 29, 2002 | 01:12 PM
1fastdc2's Avatar
Default Tranny wont go into gear
I was driving to work today when all of a sudden my tranny wouldnt go into gear. I'm gonna look at it after i get home from work today. If you guys have any ideas what it might be it would help. tia.
Old Oct 29, 2002 | 01:16 PM
Mario_D's Avatar
Default Re: Tranny wont go into gear (1fastdc2)
Wow, all sorts of tranny problems these past couple of days. You will want to check:
1. Clutch fork
2. Clutch (complete assembly)
3. Clutch fluid level (obvious but needs to be checked)
mario-
Old Oct 29, 2002 | 01:21 PM
enhancedCL9's Avatar
Check the fluid inside the tranny.. If it's bad, most of the time when the tranny is hot it won't go into gear..And if the tranny fluid is BLACK! Change soon
Old Oct 29, 2002 | 05:43 PM
1fastdc2's Avatar
Default Re: Tranny wont go into gear (Mario_D)
I just looked over it and the tranny has fluid and the clutch fluid is fine. Im just hoping its not the clutch or fork.
Old Oct 29, 2002 | 06:40 PM
3rdGteg's Avatar
clutch master cylinder maybe?
Old Oct 29, 2002 | 08:13 PM
Chugger's Avatar
Default Re: Tranny wont go into gear (3rdGteg)
is there a lot of play in the shifter and i mean a lot it could be a inner linkeage problem thats what happened to me
Old Oct 29, 2002 | 10:05 PM
3rdGteg's Avatar
Default Re: Tranny wont go into gear (Chugger)
where is the inner linkage?
Old Oct 30, 2002 | 10:57 PM
1fastdc2's Avatar
I took the clutch off and everything looked fine...but I heard that looks can be deceiving especially on a clutch. I slapped it back together and am going to try replacing the clutch master cylinder, since it was leaking a little. I just dont think thats my problem..Any more suggestions ???
Old Oct 30, 2002 | 11:30 PM
Kamin's Avatar
have you replaced the tranny fluid yet!!
this is important!!
Old Oct 30, 2002 | 11:34 PM
intekragsr's Avatar
Default Re: Tranny wont go into gear (KAMiN)
hehe i was actually about to make a post about this tonight.....
my gears a really tough to get in. Im finally forking out the money to install my clutchnet stage2 finally after 6 months sitting in my garage
Old Oct 31, 2002 | 01:55 AM
Default Re: Tranny wont go into gear (SLOW CRX)
You using the right tranny fLuid? Hope you know it takes regular motor oiL?
Old Nov 1, 2002 | 09:36 PM
3rdGteg's Avatar
It's gotta be that clutch master cylinder if it's leaking.
Old Nov 3, 2002 | 11:06 PM
1fastdc2's Avatar
i just replaced my master cylinder and tranny fluid and still doing the same thing. The pedal feels totally different too. I also hear a loud squeaking sound coming from the the slave cylinder or tranny. The fork along with the clutch looked fine.
Old Nov 4, 2002 | 02:09 AM
D16Z6racing's Avatar
Mine felt different too after I changed my clutch master cylinder. You can adjust it to your liking.
My tranny wouldn't go into gear once. And 2 miles later the whole tranny siezed. I'll pray for you. Second gear broke and somehow froze the tranny from doing anything.
phoshizzle88
May 17, 2006 10:39 PM
andrewasf77
Jun 19, 2003 07:32 PM
svtec
May 20, 2003 10:21 AM
makaveli284
Oct 2, 2002 09:53 PM
phatintegra
12
Mar 20, 2002 05:37 PM
