Grom at high altitude
Old Mar 11, 2014 | 10:54 PM
tek_civic's Avatar
Default Grom at high altitude
Anyone have experience with a Grom at high altitude?
I live at 8,500ft and would like to cross a pass that is up at 12,000ft. This is not an everyday thing, and the speed limit is low on the road anyway (though it's a fun road and i would pull off to let faster drivers pass).
Has anyone gone over this type of pass on a grom? Driver weight only 160. but we're talking less than 50% power up there.
Also if anyone have any gas mileage numbers at high elevation i would appreciate it, usually it's not too different on FI vehicles, but if the power-weight slips out of acceptable you can get some poor numbers.
Old Mar 11, 2014 | 11:03 PM
m_shake's Avatar
Default Re: Grom at high altitude
No grom experience but it's fuel injected so it should run fine, just down on power like everything at high altitude. And I can't see economy getting worse, less air will mean less fuel to maintain the same air/fuel ratio.
Old Mar 12, 2014 | 12:32 PM
tek_civic's Avatar
Less air also means less power, which means higher throttle to make it up hills and to get to speed. Often it balances out, but, as i said, if it falls out of acceptable power for its own weight, it can suffer poor mpg.
7mile
Aug 30, 2005 01:59 PM
wm5holla
Jul 25, 2003 03:09 AM
RagingAngel
Jul 10, 2001 06:40 PM
