Please help idk what drive shafts to buy
Okay so here's the deal I bought a 92 civic hatch and it needs drive shafts but I don't know what ones to buy. The car has a swapped d16a6 and I know there's a difference in trans from 88-91 so there's my problem I don't know what trans is currently in it and I don't know what year the engine is with I know the head is stamped 8l8 so I guessing the block is a 88. So what I need to know is there anyway I can find out what trans is on it so I can buy axels. Please let me know thank you. Any info will help
I suggest that you remove current axles and drive to a GOOD PARTS STORE and ask nicely if they could help you by matching what you have, then by backward searching, find what applications the new axles fit, thus giving a clue what is trans attached to the car you own. Good luck.
Regards
Dave
Regards
Dave
X2 with Dave, remove the axels and take it to a parts store to be on a true safe side. But you should be able to run an EG (92-95 Civic) drive shaft being how most series of the same type (B,H,F,D,K) are interchangeable.
Hatchlife92
11
Mar 12, 2014 12:15 PM
EnjoyTheRideDC2
15
Sep 14, 2005 12:18 PM
