215/?/16 on 8" wide wheel
Old Mar 10, 2014 | 10:08 PM
bayFERIOroan's Avatar
Default 215/?/16 on 8" wide wheel
I have some xxr 521's they are 16x8 20 offset I would like to run on my four door eg8, I was looking at 205/45/16's but would like to eventually run some autox on the weekends. I know that the 205 is not much of a stretch but I would rather run a 215 being that it is the correct size. what series sidewall would I need to run to get them to clear? if they will even clear? ill be rolling my fenders and will have a camber kit I just do not want to run a crap load of camber. the car is not low its on ground controls and koni yellows with around one finger gap all the way around. thanks for your suggestions
Old Apr 13, 2014 | 10:58 AM
jayrdee's Avatar
Default Re: 215/?/16 on 8" wide wheel
I don't know if this would be any help for you but I have 16x8 +20mm offset with 205/40/16 tires and they only rub in the rear, but thats just because im pretty low to the ground and i didnt do a very good job at rolling my rear fenders at the time. even then though, its not bad at all. it only rubs when i hit a major bump on the highway.
i have about -3 degrees of camber all around as well.
here are some pictures for reference
For what you are wanting, im sure you would be fine with anything as long as you roll your fenders and have a camber kit.
Old Apr 15, 2014 | 06:15 PM
spAdam's Avatar
Loved
Community Favorite
Thank you to the both of you for aspiring to put man tires on your wheels
Old May 14, 2014 | 11:49 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Trade your XXRs for 7" wide rotas in a normal offset and run real tires.
Old Jun 18, 2014 | 08:44 AM
ahhwhat?'s Avatar
wrong wheels to auto x with?
Old Jun 22, 2014 | 07:47 PM
chickenlittle's Avatar
The tires would fit fine. Not sure about auto-x with xxr wheels tho
kennedyDAb18c5
Acura TSX
11
Jul 7, 2009 05:45 AM
Freshdot
Apr 7, 2009 06:49 AM
p_ep_si
72
Sep 18, 2005 04:38 PM
awdvr6
May 25, 2005 07:25 PM
Halo
Oct 30, 2004 10:07 AM
