Rusty rex tie rod ends
Old Mar 10, 2014 | 05:34 PM
Glowicki's Avatar
Default Rusty rex tie rod ends
I tried to remove the tie rod ends from my 91 crx Dx. I was unable to budge the lock nut. Is there a super secret honda trick to getting these buggers off? I soaked them with pblaster every hour since 8am cst. Still no movement.
Old Mar 10, 2014 | 06:01 PM
F22Master's Avatar
Default Re: Rusty rex tie rod ends
Old Mar 10, 2014 | 06:05 PM
1998GsRIntegra's Avatar
Heat and or more leverage.
Old Mar 11, 2014 | 02:44 AM
Freemananana's Avatar
I took a big (22m?) wrench I bought at lowes and a rubber mallet. Bought 20 swings later, POP. Easy. Probably not the way you are suppose to do it. But I can't imagine it being much worse than busting out the torch and heating them. That works well too.
Old Mar 11, 2014 | 08:51 AM
radex7's Avatar
I am pretty sure I had to cut into mine with a die grinder with a cutoff wheel (no heat torch). It heats it up, and relieves the tension on a nut. I did not have to cut all the way either, just a groove, then finished it with a wrench and a socket. Of course you will need a new nut!
Old Mar 11, 2014 | 08:59 AM
Tyson's Avatar
lock the tie rod with an adjustable wrench to something like the swaybar. then put the 22mm on the lock nut and sit so you can push with your leg.
dont kick it, just push.
another tip is that the EG and DC's use 19mm lock nuts, with the same thread. i like switching it out with those so i dont have to carry a 22mm wrench in my toolbag, since its the only 22mm on the car.
Old Mar 11, 2014 | 03:10 PM
Glowicki's Avatar
I went out and bought a 19mm and 22mm box end wrench. I had to soak the lock but with blaster overnight but I finally got passenger side out. The driver side is still stuck. I'm saying f*** that one and replace the inner tie rod as well.
Old Mar 11, 2014 | 03:26 PM
burnoutboy's Avatar
The Credible Hulk
The REAL bitch is pinning the new ones back in there as good as the originals were with the steering rack still in the car. THAT was tons of fun...
Old Mar 11, 2014 | 04:14 PM
Tyson's Avatar
why is that a problem?
you just use two wrenches...
its only stuck on there good because of corrosion.
Old Mar 11, 2014 | 04:18 PM
KevinEF7's Avatar
Good tip with the EG/DC tie rod lock nut Tyson. Just added those to my shopping cart on Majestic Honda since I have the front end apart
Old Mar 12, 2014 | 05:41 AM
That was an amazing tip. The 19mm is a common size. But that 22mm is quite rare. I think the only other thing it does is my O2, which may not be the factory size.
Old Mar 12, 2014 | 03:15 PM
burnoutboy's Avatar
The Credible Hulk
Wait, he's talking about the regular lock nut that holds the outer to the inner? I work on early 90s Honda's a LOT and have never run into an issue getting it off due to corrosion or anything else for that matter.
I think I MAY have misread. I just assumed he was talking about the tie rod lock washer. Which should DEFINITELY be hammered to the rack like this, and which is a BITCH to hammer the new one on properly with the rack in LOL. Hence my use of the word pinning.
Sorry for the confusion. Never had a problem with the lock nut, just two wrenches like everyone says.
Old Mar 12, 2014 | 04:41 PM
Tyson's Avatar
wrong topic.
Old Mar 12, 2014 | 05:26 PM
Glowicki's Avatar
Anyway, this is kind of on topic, but the rack and pinion boots for the driver and passenger side have different diameters which attach to the rack. Just throwing this out there for anyone searching for it. There is about a 5mm difference between the two with the driver side as the larger one.
Old Mar 14, 2014 | 06:58 AM
burnoutboy's Avatar
The Credible Hulk
wrong topic.
.I think I MAY have misread....
Yeah, think I covered that champ. Thanks for confirmation though. I can sleep again.
longshot
Dec 25, 2008 06:39 PM
PINKS
Apr 19, 2006 08:16 AM
PINKS
Apr 18, 2006 07:31 PM
teler86
Jan 25, 2006 04:47 PM
zccr-xsi
Sep 25, 2005 06:24 AM
