Idles too high to pass emissions, but won't go any lower.
Old Mar 10, 2014 | 03:31 PM
cashcastellon's Avatar
Default Idles too high to pass emissions, but won't go any lower.
My 1994 civic is idling at around 450, but it needs to be less than 400 so I can pass emissions. I lowered the idle by what seemed like a ton, but it apparently only went down 7 rpms. It is as low as it can go without stalling, until I plug the sensor back in, then it jumps back up a ton. What else could be an issue that I haven't addressed?
Old Mar 10, 2014 | 03:34 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: Idles too high to pass emissions, but won't go any lower.
That doesn't sound right to be honest
Old Mar 10, 2014 | 03:48 PM
I unplugged the sensor, and(with the engine on) adjusted the idle as low as it would go. At one point it even stalled out. I got it down to about 100 RPMs, but when I plug the sensor back in it jumps up to like 450. When I kept the sensor unplugged, it did like 1000 RPMs for some reason.
Old Mar 10, 2014 | 03:57 PM
Former User's Avatar
The stock idle speed for your car is around 650 rpm, so your first post makes no sense.
Old Mar 10, 2014 | 06:48 PM
B_Swapped93's Avatar
700-750rpm's is the standard adjust the idle screw if you want it higher or lower.
Old Mar 10, 2014 | 08:26 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
He's talking about the no load unplugged EACV test where it's supposed to idle around 420.
Old Mar 10, 2014 | 08:37 PM
fleabag's Avatar
Attachment 357445
Unwittingly most likely.
Old Mar 10, 2014 | 09:13 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Probably, at least he has the complete idle set procedure straight from the FSM now.
type r em1
Jul 4, 2019 11:46 AM
Ercol215
Honda Civic (2001 - 2005)
May 6, 2015 02:18 PM
5thGeneration
Jan 3, 2008 01:49 PM
gsr squirrel
Mar 29, 2003 01:55 PM
InfamousRS
Jul 31, 2002 12:14 PM
