Need help with lowering 1997 Accord...
Old Mar 10, 2014 | 01:29 PM
DorkFishh's Avatar
Default Need help with lowering 1997 Accord...
My son bought some cheap springs off of ebay to lower his car and they blew out the struts....
So I am trying to help fix this.
He is looking to lower his car. He is not competing. So I think a nice spring / strut combo is what we are looking for. Can you guys please give some suggestions as to what products to go with?
Thank you
Old Mar 10, 2014 | 02:34 PM
DorkFishh's Avatar
Default Re: Need help with lowering 1997 Accord...
Decided to go with Koni Str.t struts.
Old Mar 10, 2014 | 02:38 PM
MAD_MIKE's Avatar
MM Gruppe B
Eibach springs.
Old Mar 10, 2014 | 02:43 PM
DorkFishh's Avatar
Not sure which springs he bought off of ebay...but wondering if we could get away with just purchasing the struts?
Old Mar 10, 2014 | 03:00 PM
MAD_MIKE's Avatar
MM Gruppe B
If he does not know what the spring rate is then you will not be able to correctly pair the shocks to springs. If the struts are too stiff, the car will crash over bumps, if too soft the car will bounce all over and feel uncontrollable at times.
Old Mar 10, 2014 | 06:33 PM
djkurious's Avatar
Function form type 1's are great.
Old Mar 10, 2014 | 07:02 PM
DorkFishh's Avatar
I just went with the Eibach sportline springs
Old Mar 10, 2014 | 07:04 PM
DorkFishh's Avatar
I do have a question... should I get the recommended alignment kit? Kind of expensive
Old Mar 11, 2014 | 01:21 AM
MAD_MIKE's Avatar
MM Gruppe B
On the rear if you need to reduce camber, adding washers between the upper rear control arm and the body will reduce camber, however you will need to purchase longer bolts to use the washers. ~3 washers per degree of camber.
On the front you may need to use a 'camber kit' that will either be an adjustable BJ or a control arm with adjustable BJ.
SPC makes adjustable BJ in -1.5-1.5 or -3.0-3.0
However I would call and speak with someone at Eibach first to see what they recommend for the lowering kit you purchased.
Old Mar 11, 2014 | 06:24 AM
DorkFishh's Avatar
Well, it looks like the Eibach springs are on back order. They only other option (purchasing from the same company) is H&R Sport Spring set.
How do these compare to the Eibach springs?
My son mentioned K Sport.
I have already purchased the Koni Srt.t struts.
Old Mar 11, 2014 | 12:41 PM
CD5B2's Avatar
I have koni str.t's w/ eibach pro kit. My only complaint is they seemed to have put a thin layer of cheap paint on them. They rusted on the bottom within a year up here in the snowbelt. I emailed Koni and they said the maximum drop they can handle is 1.5" so just keep that in mind when choosing a spring. Check into polyurethane suspension bushings as well. They make quite a difference compared to rubber ones imo.
Old Mar 11, 2014 | 09:16 PM
19Accord97's Avatar
I would just save the headache, return everything, and just get a set of D2 coilovers or Function Form Type 1's. Then you dont have to worry about spring rates, struts, etc. On a side note, let this be a lesson to not let your son buy no name cheap junk on eBay.
Old Mar 11, 2014 | 09:21 PM
MAD_MIKE's Avatar
MM Gruppe B
H&R is a quality brand commonly found on road racers/auto X cars. Call H&R and see what springs they recommend to compliment the Konis.
Old Mar 12, 2014 | 03:12 PM
accordturb96's Avatar
I use the H&R full coilovers on my 96 and I love them, ride smooth yet handle like a porsche! A little soft at times but they're well rounded. I have 17in rims with low pro tires and have less than an inch of fender/top of wheel gap. hell of a camber kit front and rear to make up for the drop though
AFAccord
Apr 30, 2011 08:04 PM
rekreb38
Suspension & Brakes
Nov 3, 2010 10:30 AM
stickyrice_JDM
May 13, 2009 02:49 PM
aln2590
Jul 30, 2007 03:17 PM
bolognatits
Aug 29, 2001 11:33 AM
