94 accord lx tranny trouble
Replaced tranny with newer model,but still in same group(AOYA to MPJA) all gears work properly except reverse. It will not engage, sounds like to gears spinning fast but opposite bouncing off each other. Is it junk or is there a quickfix.
Verify that the fluid level is full after selecting every gear to purge any air.
If you shift from 1st to reverse does that change anything?
Reverse is controlled via the valve body inside the transmission, no solenoids control the shifting. Fourth gear selector may be stuck, damaged, or the reverse gear/spur gear needs to be replaced.
You may try adding a cleaner/solvent to the fluid after a change to see if that will unstick or clear out any debris that may be jamming the components.
Use to be able to contact a moderator/administrator to change it, but I do not know if they still do that. Might have to just start again fresh with a new account/screen name.
Heres something forgot to mention, hope it's important, replacement tyranny has gear indicator dohicky on it ,old one doesn't.
What does the sticker(barcode) on the front of the trans say? MPJA? If so then it is an Odyssey transmission.
