Transmission & Drivetrain Gearboxes, Differentials, Clutches
Are b series gears changeable within different tranny cases?
Old Mar 9, 2014 | 06:09 PM
uhhmaysing's Avatar
Default Are b series gears changeable within different tranny cases?
Is it possible to put gsr tranny gears into a ls tranny case? I'm fairly new at transmissions and have a gsr tranny with a bad case and an ls tranny with a good case. Thanks
Old Mar 10, 2014 | 01:16 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Are b series gears changeable within different tranny cases?
Cases are the same. You will need to properly check shim clearances on the mainhsfta and diff., if the GSR diff uses tapered bearings you'll either have to convert thos to ball bearings or move the spacers to new case and shim accordingly.
JDMdamian95
Oct 17, 2006 09:42 AM
auburnBoy
Oct 3, 2005 09:35 PM
Endoe
Nov 24, 2004 01:04 PM
dustrag
Jan 27, 2004 12:11 PM
b18bturbo
Nov 20, 2002 09:20 AM
