Fuel pump
Old Mar 9, 2014 | 01:39 PM
girlcrx's Avatar
Icon2 Fuel pump
My 88 crx is only getting 9 volts to the main relay and the fuel pump is not turning on. I have replaced the main relay and still nothing.
Old Mar 9, 2014 | 05:37 PM
brixcivic's Avatar
Default Re: Fuel pump
then its your fuel pump
Old Mar 9, 2014 | 06:04 PM
d4g4m's Avatar
Remove relay. Looking at connector with 3 wires on top, 4 on the bottom, use a short jumper wire between term 1 yel/blk [bot. right] and term 3 blk/yel [bot second from right] pump should run constant. Check fuses 34 haz, 37 ECU, 14 alt, 2 starter. Check for good ground on blk wire at engine thermostat housing. Remove storage comp behind seats for access to pump/fuel level connector. Reconnect relay. Connect tester to fuel pump wires. Turn ign on. Tester should show volts for 2 sec. If yes but pump not running, pump is bad. Drop tank to replace.
briansrc
Jul 13, 2010 09:01 AM
ef-hatchcrap
Feb 13, 2010 12:02 AM
zippakilla
Feb 6, 2009 04:01 AM
insomniac791
Jan 22, 2004 04:23 PM
Jamison
Jul 11, 2002 12:07 PM
