overheating
Old Mar 9, 2014 | 06:28 AM
jsinher3's Avatar
Default overheating and running lean?
i have a H2B set up on my civic EF, it is a JDM H23A VTEC stock motor with bolt ons. i am using hondata s300 to run the car however, the car keeps overheating. i already replaced the fan switch and thermostat and bled the system as best as i know how. i noticed that the fan does not turn on when it starts to over heat, but when i loop the fan switch plug it turns on or when i do the engine overheat override on hondata. does anybody know what might be wrong?
the second problem i am having is my car is running lean at least that's what i think, i look at the AF and it is at 1.0 - 0.98. i cant get it tuned yet because i dont have the money at the moment, im using a hondata stock h22 base map with 440cc injectors. can anybody point me to the right direction on what i should adjust or look at? also i wired a lc-1 wideband however i dont know how to pull it up on hondata or if i wired it right i followed this guide http://www.xenocron.com/install/Xeno...etup-Guide.htm
please help me!!
Old Mar 9, 2014 | 07:01 AM
REEMB18C1's Avatar
Default Re: overheating
wat is the fan switch temp set at in the s300
Old Mar 9, 2014 | 10:24 AM
jsinher3's Avatar
im not sure, where do i find it? i mean i'm using a h22 hondata basemap so im assuming it is where it needs to be
Old Mar 9, 2014 | 11:11 AM
jsinher3's Avatar
bump
Old Mar 10, 2014 | 02:25 PM
jsinher3's Avatar
ttt
Old Mar 10, 2014 | 04:58 PM
mechanix619's Avatar
Check Parameters tab and then Protection in SManager.
Old Mar 11, 2014 | 02:46 PM
jsinher3's Avatar
ok ill check, thanks
does anybody know if it would be running lean because i havent changed the stock fuel pump on the hatch?
hmongxcuz
15
Feb 29, 2012 07:23 PM
EJ8 GSR-T
Aug 20, 2009 08:38 PM
Aaron.Hillman
May 30, 2007 08:27 AM
