ep3 cranks but won't start?! help!
Old Mar 8, 2014 | 01:22 PM
91_Project's Avatar
Default ep3 cranks but won't start?! help!
Hey guys so I bought an 02 ep3 Si and the previous owner said he believed it needed a new motor. He claimed to be driving normal and the car just bogged down on him and wouldn't start again, he initially thought he ran out of gas. The car has what I believe to be the original k20a3 (can't find the block code lol), as well as I/H/E and kpro.
Fast forward to now, the car has gas in it and will crank but will not start. When I crank it at first it sounds normal then seems like it's starts cranking faster almost like there is no resistance. I don't hear any knocking or odd sounds coming from the motor so I'm not convinced that it's blown.
I have the fuel pump priming and I have fuel at the rail as well as voltage to each injector with the key in the on position.
I would like to check the coil packs to see if they are in spec with my multimeter but I'm not sure how or what ohms they should be putting out?
I am also waiting for someone to come help me crank the car while I use a screwdriver to check for spark, unless there is another way to check for this?
I would like to check off the obvious before i go any further, and by that I mean fuel/air/spark. How do I make sure air is getting in? Please help if you have any ideas, thanks!
Old Mar 8, 2014 | 01:57 PM
91_Project's Avatar
Default Re: ep3 cranks but won't start?! help!
Update: car seems to be getting NO SPARK in all four cylinders. I checked with a screwdriver (the only way I know how)
What could cause the car to not fire on any cylinder? I dont think it's the immobilizer bc the green key flashes a couple times when you put the key in the on position but then goes away. Also where are the oem grounds supposed to be on a stock si?
Old Mar 8, 2014 | 02:02 PM
Jjbaehr's Avatar
Check mechanical timing, they are known to stretch the chain and skip then bend valves, a simple compression test will let you know, as far as spark goes pull the coil stick a plug in the end of it and have someone crank the car and watch for spark while putting the plug near something metal.
Old Mar 8, 2014 | 02:38 PM
91_Project's Avatar
Please excuse my ignorance but if the timing is off would that cause the car to not throw any spark at all?
Old Mar 9, 2014 | 06:09 AM
91_Project's Avatar
I just realized that this is in the wrong section, can a mod please move to the rsx/ep3 section?
Old Mar 9, 2014 | 05:01 PM
91_Project's Avatar
Anybody have any ideas? Can the timing being off cause the car to not throw any spark in any cylinder?
Old Mar 12, 2014 | 03:11 PM
Jjbaehr's Avatar
I'm not too sure about it disabling spark, I'm sure it could if the cmp sensors are that far out of phase. Remove the valve cover and check your timing marks!
Old Jul 2, 2014 | 03:53 AM
Zedicous's Avatar
But check fuses first
Old Jul 30, 2014 | 11:49 AM
SquidByrd's Avatar
Was this issue ever resolved?
z06eateR
28
Mar 23, 2009 09:38 AM
champLSinteg
Mar 5, 2008 12:00 PM
92jdmxsiteg
May 26, 2007 04:24 PM
CustomTeggy44
Jul 4, 2004 03:04 PM
