2003 no compression all cylinders
Old Mar 8, 2014 | 09:22 AM
gpapa's Avatar
Default 2003 no compression all cylinders
2003 won't start, has fuel and spark, no compression all cylinders. Try to start and it spins like a top but won't start.
Timing chain spins, valves moving up and down but no compression in pistons. What to check next? Granddaughter's car, trying to help her out here. She replaced the engine 2 years ago but that warranty ran out. Any ideas?
Old Mar 9, 2014 | 09:40 AM
Lost Again's Avatar
Default Re: 2003 no compression all cylinders
Sounds like the chain jumped and bent valves. Pull the cover(s) and check the timing on the chain.
Old Mar 9, 2014 | 10:51 PM
MAD_MIKE's Avatar
MM Gruppe B
K24 problems. Head needs a rebuild.
Known issue is on startup the auto tensioner, which uses oil to maintain tension, can fail and lets the chain fall off the sprocket. Usually happens at startup, start engine, crank spins, cams do not, pistons smack open valves and bends them.
BTW this is the 90-02 forum. '03-present forum may have better answers for replacement/best deals.
Dlarsson112
Jan 20, 2019 09:07 PM
osgn
Mar 1, 2009 01:31 AM
vinuneuro
17
Oct 20, 2008 06:17 AM
95silverluder
May 30, 2008 08:44 AM
11seclude
Aug 30, 2005 06:28 PM
