will car start with bent valves?
Old Aug 28, 2005 | 09:20 PM
11seclude's Avatar
Default will car start with bent valves?
i had a huge 3-2 miss shift and my motor must of rev past 9k the car died after that and never started since, i want to do a compression test but i have forged internals and i know they need to get hot and expand so ho do i find out if my pistons are shot or just bent valves?
Old Aug 28, 2005 | 09:29 PM
Adi Radoncic's Avatar
On Fire!
Default Re: will car start with bent valves? (11seclude)
Leakdown tester is the answer!
Check this out...
http://www.c-speedracing.com/h...n.php
Old Aug 28, 2005 | 10:17 PM
BoOsTiN Dc2's Avatar
yeah a leakdown test would be best. but bent valves from miss shifting usually still start up and run, just run shitty.
Old Aug 29, 2005 | 05:01 AM
11seclude's Avatar
Default Re: will car start with bent valves? (tRaCeBuStA)
that's what i heard but when i try to start the car it just turns freely.it will not start for gold,what could cause the car to not start? i don't understand................
i going to borrow my friend compression tester today, what numberes should i look for on a h22 with 9:1 compression pistons, and would having forged pistons affect the readings since the car wont start to get the pistons to expand and seal?
Old Aug 29, 2005 | 06:00 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11seclude &raquo;</TD></TR><TR><TD CLASS="quote">that's what i heard but when i try to start the car it just turns freely.it will not start for gold,what could cause the car to not start? i don't understand................
i going to borrow my friend compression tester today, what numberes should i look for on a h22 with 9:1 compression pistons, and would having forged pistons affect the readings since the car wont start to get the pistons to expand and seal?</TD></TR></TABLE>
Its not starting because you arent getting compression.. When the valves close they seal the cylinder, since your valves are bent they arent sealing the cylinder and arent allowing the engine to compress the air/fuel..
Old Aug 29, 2005 | 06:05 AM
adictionbass's Avatar
Default Re: will car start with bent valves? (tgreaves)
pull the head off, take pics
Old Aug 29, 2005 | 07:45 AM
11seclude's Avatar
well i did a compression test and i have no compression on all cylinders. I hope my pistons are still ok
Old Aug 29, 2005 | 12:27 PM
LSTEG96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11seclude &raquo;</TD></TR><TR><TD CLASS="quote">well i did a compression test and i have no compression on all cylinders. I hope my pistons are still ok</TD></TR></TABLE>
buddy of mine just money shifted.... went 107 in 2nd on his 3 series bmw. there wasnt one good part left in the entire motor. The local bmw dealership said all valves, cylinders, pistons, bearings,everything.
good luck
Old Aug 29, 2005 | 01:30 PM
11seclude's Avatar
Default Re: will car start with bent valves? (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">
good luck</TD></TR></TABLE>
how did his motor sound when all that happend?
mine don't make any weird sound it just sounds lik it turning real fast
Old Aug 29, 2005 | 02:05 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
it sounds like its turning really fast becuase u have nooooo compression
Old Aug 29, 2005 | 08:16 PM
Default Re: will car start with bent valves? (street dreams)
a leakdown test would be better. It would narrow it down better.
Old Aug 29, 2005 | 08:26 PM
1700anddroping's Avatar
i just fixed a car like this the other day....he did the same exact thing.but all his int. valves looked like the letter L.....while we had the head off.we just put ferrea vlves in .....for as much nitrious we are spraying we would be dum not to.
his turned over freely also.look at it this way the head is gonna have to come off,so get started and let me know.also look and see if your timing is correct before you take it off.
harv
Old Aug 29, 2005 | 08:39 PM
mike93eh
Guest
Posts: n/a
my car has started and ran with ZERO compression in two cylinders. i had bent valves..
Old Aug 29, 2005 | 08:42 PM
AspectIndustries's Avatar
Default Re: (mike93eh)
Happen to a friend, his Fully built NA Gsr was destroyed! 12:1 Piston etc etc..
Compression read: 160- 60 - 30 - 0
Bent most of his valve, and pistons were either in peices or cracked. Yes, you know the results...
Hope nothing bad happen to your car though.
but had compression in 2...that is why it started and probably ran like a diesel.
harv
Old Aug 29, 2005 | 08:50 PM
mike93eh
Guest
Posts: n/a
Default Re: (1700anddroping)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1700anddroping &raquo;</TD></TR><TR><TD CLASS="quote">but had compression in 2...that is why it started and probably ran like a diesel.
harv</TD></TR></TABLE>
well yea. i was just answering the question in the topic.
Old Aug 29, 2005 | 08:58 PM
D@nnY's Avatar
your motor is fubar
Old Aug 30, 2005 | 07:45 AM
11seclude's Avatar
Default Re: will car start with bent valves? (1700anddroping)
ok am going to start to pull the head,about the timming should i put the motor to tdc and put the cam gears back to zero befor i do anything?
Old Aug 30, 2005 | 07:48 AM
yes just to see if it has jump timing...most likely it has but could not have.just something i like to check...let me know how it goes.
harv
Old Aug 30, 2005 | 09:47 AM
11seclude's Avatar
well i just took the turbo and manifold off the car and i heard something rolling around in the manifold when i shook it out it was 6 small smoth looking rock like objestcs. also as i was looking in the exhaust ports all but 2 valves are closed the ones closest to the timming belt are wide open.
Old Aug 30, 2005 | 09:49 AM
b18bturbo's Avatar
msotlikely pistons touched the valves and melted together causign the rock objects
Old Aug 30, 2005 | 09:52 AM
11seclude's Avatar
Default Re: will car start with bent valves? (b18bturbo)
you don't think i have a big hole in my pistons do you?
Old Aug 30, 2005 | 09:55 AM
On Fire!
big possibility if your **** just turnsover easy as hell, did you check your timing belt to c if that still there hehe?
Old Aug 30, 2005 | 10:02 AM
b18bturbo's Avatar
Default Re: will car start with bent valves? (Adi Raaa)
pull the head to see the damage if you seeing 0 compression across the board and metal pieces you can definitely find out that you did some major **** to your engine.
just pull it and most likely you gonna find the problem simple as that
Old Aug 30, 2005 | 10:06 AM
11seclude's Avatar
yes it is still there and the timming is good.
