Suspension & Brakes Theory, alignment, spring rates....
Wilwood DynaPro H/A & 13inch wheels?
Old Mar 7, 2014 | 05:16 PM
K20EF8Dx's Avatar
Default Wilwood DynaPro H/A & 13inch wheels?
I have heard the DynaPro Honda/Acura 4 piston calipers will clear with Belak and other drag racing 13" wheels. Trying to find some insight on this before ordering a set and being disapointed.
This kit is for Honda and Acura models originally equipped with 262mm diameter rotors. These calipers bolt directly to the stock mounts on factory spindles, fit over the OE 262mm diameter rotor, accept the OE brake hose. proven DynaPro series four piston calipers, the forged billet bodied DPHA caliper delivers high-strength clamping force and positive stopping power. Four stainless steel pistons provide fully balanced pad loading, along with the corrosion resistance and thermal retardant qualities of the stainless alloy that will keep your calipers cooler and running trouble free for many more miles. Calipers work perfectly with the OE master cylinder. with either black or red high-gloss, high-temp, brake fluid resistant sealed powder coat. New SFWD Honda 4 piston brake kit that FITS behind 13" Welds, Nitro, Belak.
K20EF8Dx
Oct 30, 2017 08:40 AM
CivicBristol
Feb 23, 2013 07:43 AM
NoSmoking
Aug 14, 2008 06:49 PM
prostreetonline
Oct 23, 2005 10:07 AM
redzcstandardhatch
23
Apr 18, 2005 03:44 PM
