clutch replacement: what will i need?
Old Mar 7, 2014 | 01:42 PM
mjf6866's Avatar
Icon2 clutch replacement: what will i need?
hi guys, i'm getting ready to put in a new clutch on my 90 civic dx 1.5 hatch.
i bought the Exedy Complete Clutch kit Part# 08012 off rock auto and also a new cable. will i need any additional seals or gaskets or anything else? i'm taking it into work to have a tech do it on the lift for me.
any time saving tips or anything we should be warned about before diving in would be greatly appreciated!
thank you
Old Mar 7, 2014 | 01:49 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: clutch replacement: what will i need?
You will need 12 point sockets for both the flywheel, and pressure plate bolts (can't recall size off the top of my head)
Old Mar 7, 2014 | 01:50 PM
mjf6866's Avatar
ok, thank you for the tip!
the tech will have every tool imaginable so i should be good there. i was mainly concerned with tearing it apart and finding out that i need a seal or another gasket somewhere.
Old Mar 7, 2014 | 02:02 PM
4drEF's Avatar
Keyboard Humorist
As long as it's off, might as well change the engine and tranny oil.
It's also the time to remove the flywheel and have it resurfaced.
While the flywheel is off, you can get to the rear main seal. Great time to replace it!
http://crxcommunity.com/viewtopic.php?t=226
Old Mar 7, 2014 | 07:20 PM
F22Master's Avatar
+1 on all of that ^
Old Mar 7, 2014 | 10:59 PM
Glowicki's Avatar
If I remember correctly, the pressure plate and flywheel bolts are 12 point 10mm and 12 point 17mm respectively.
Old Mar 9, 2014 | 07:08 AM
mjf6866's Avatar
thanks for all the tips guys!
aZnjCC
Mar 6, 2006 07:09 AM
Corinthians
Sep 28, 2004 11:46 AM
PokeyD16Z
Jun 8, 2004 06:14 AM
lionhart
Apr 18, 2003 09:19 AM
matht27
Jul 16, 2002 04:34 AM
