Del sol fan wiring?
I have a 94 Del sol that the previous owner ghetto rigged the fans to run off a switch. Id like to remove the switch and go back to how it should be set up(stock).
Not sure where I should rewiring wires to. Right now I have a plug plugged into the thermostat. The fans are wired to straight power with a switch.
Lol because there is two fans. Is it that big of a deal a minor typo? The point is BOTH FANS are wired to a switch. Radiator fan,AC FAN or what ever it is.
I flip a switch and BOTH COME ON. Id like to undo this and go back stock. But thanks for the ball busting.
I'm really not trying to bust your *****. What I've been trying to figure out is whether your first post was a typo or reflected the true problem. How can I or anybody else help you if the issue is not completely clear?
So, both the radiator and condenser fan circuits are spliced together and controlled by a switch.
Start by posting clear pictures of how the previous owner installed the switch and modified the fan wires.
Rafe Altschuler
14
Aug 11, 2015 04:10 PM
delsol88
Apr 24, 2012 04:09 PM
