93 del sol baro sensor ??? code 13
Old Mar 6, 2014 | 11:52 PM
jenishereto's Avatar
Default 93 del sol baro sensor ??? code 13
keeps throwing code 13 baro sensor , Just where is this located I have a cheap chiltons that im going to use to start my next fire with has no info on this sensor other than its listed in the diagnostic chart , no reference to where its at > Is it the same as map sensor? I would think not but had to ask. and is this part really 250 at a regular parts store ?:
Old Mar 7, 2014 | 04:16 AM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: 93 del sol baro sensor ??? code 13
Everything I've read in the past has indicated that the barometer is built into the ECU. Replace the ECU, and it should resolve your problems.
scerbz
17
May 13, 2013 08:39 AM
pip9
Jan 18, 2012 04:38 PM
westside49block
Feb 2, 2008 08:55 PM
RiversideS13
Jul 30, 2007 02:17 PM
