Honda accord V6 98 model Error code
Old Mar 6, 2014 | 10:46 PM
lwise's Avatar
Default Honda accord V6 98 model Error code
I need urgent help on this.
I noticed that my car delays in selecting gear after driving for few minutes.This persist for a week and I took the car to a mechanical.We changed the transmission oil but the problem still continues.We tried replacing the solenoid switch on the transmission but the problem still remains.I insist that the mechanic fix back the original solenoid switch removed and I took the car for a diagnostic test.The error code was P1773 and P1768,the solenoid switch was tested and to my surprise we discover that it was still OK.
The man that did the test conclude that we should change the brain box of the car.
Im so scared to do this.Can anyone help me with the possible solution.
Old Mar 7, 2014 | 07:30 AM
lwise's Avatar
Default Re: Honda accord V6 98 model Error code
Any help
Old Mar 7, 2014 | 10:44 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Originally Posted by lwise
Any help
In lieu of any actual testing,(which you seem to want)try changing the Main Relay......
Old Mar 7, 2014 | 12:13 PM
lwise's Avatar
where is the main relay located. Are you referring to the gear switch.
Old Mar 7, 2014 | 11:56 PM
MAD_MIKE's Avatar
MM Gruppe B
Check all your fuses, try looking at #6 under dash fuse. If it is blown it may cause similar problems.
Also look into this link > http://troubleshootmyvehicle.com/hon...d-tests-page-1
Old Mar 9, 2014 | 10:47 PM
lwise's Avatar
Where is the dash fuse
Old Mar 16, 2014 | 11:18 PM
lwise's Avatar
This forum is not helping at all.Too bad.
Old Mar 17, 2014 | 12:56 AM
MAD_MIKE's Avatar
MM Gruppe B
Makes no reference to doing any kind of testing or work.
Blames forum.
Seems legit.
Old Mar 17, 2014 | 03:14 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Blames forum.
Seems legit.
Ha!!!
psphilip
Sep 9, 2013 04:43 AM
joshua89
Jul 30, 2011 01:36 PM
engled
Feb 8, 2011 04:42 PM
jwc104
Nov 17, 2009 07:44 PM
ochodude
Jul 9, 2004 04:43 AM
