92 civic vx starting n driving issues need help!!!
Old Mar 6, 2014 | 06:45 PM
OhMy-EK9's Avatar
Default 92 civic vx starting n driving issues need help!!!
I'm having some problems w my hatch I had it running at one point its a 92 vx w d15b7 stock everything it ran but idle bad n drove like crap after I installed the motor, was throwing code 3 for map so I manually wired the map sensor to ecu code went away. Now the car doesn't crank at all so I bought new starter and it won't crank for long period let alone start up it cranks for about 3 seconds and it stops cranking on its own.
Old Mar 6, 2014 | 06:46 PM
OhMy-EK9's Avatar
Default Re: 92 civic vx starting n driving issues need help!!!
No cells pop up at all
Old Mar 6, 2014 | 09:28 PM
slowcivic2k's Avatar
Check your starter ground, and all of the other grounds in that matter. A lot of people disregard them when changing engines.
Check the battery.
Did this engine ever run at all?
Old Mar 7, 2014 | 01:06 AM
n*werk's Avatar
check tps and map sensor plug. sound like you swap plug.
Old Mar 8, 2014 | 01:33 PM
OhMy-EK9's Avatar
Map n tps r correct the hqrness I used didn't have a map so I wired one in myself it has the tranny ground n that's about it has battery in rear n that's grounded as well now the fuel pump kicks on every time I switch it to the start position n I don't get any crank at all now
Neckbeard
Nov 14, 2018 02:46 PM
CXHBumpin39
12
Jun 7, 2013 05:41 PM
aznfreakyguy
Jul 3, 2011 12:24 AM
eg:R
Dec 21, 2006 03:14 PM
doobiesack23
May 11, 2005 05:03 PM
