smog help - where to find an obd1 cat?
Old Mar 6, 2014 | 09:48 AM
boomsplat's Avatar
Default smog help - where to find an obd1 cat?
hey guys i have two efs and one of them is completely stock and the other has a b16a2 swap in it. I'm torn between taking car two ref because i know ill fail i need a obd1 cat and can't find one and idk if my setup would pass. my other option is taking the motor out of my stock one and installing in the b16 one and just smoging it that way which idk if i could get away with anything would help thank you.
Old Mar 6, 2014 | 09:55 AM
Freemananana's Avatar
Default Re: smog help
What's the question?
"Should I break the law?"
"Should I pull a fast one on the smog ref?"
Either find the right exhaust manifold and cat or check your local laws and see if you can go with a generic cat.
Old Mar 6, 2014 | 10:21 AM
boomsplat's Avatar
basically haha here in cali its ridiculously strict any ideas on where to find a obi 1 cat
Old Mar 6, 2014 | 10:51 AM
4drEF's Avatar
Keyboard Humorist
You are really confused.
You can't just "smog" a B16A2 swap. You need to see a ref first and get the swap approved.
The B16A2 was only available in the OBD2 Del Sol in the U.S. so you are in for a headache. You need to convert your emissions controls to OBD2 standards. Basically, this means and OBD2 ECU and no check engine light. OBD2 introduced a pressure sensor in the fuel tank that doesn't exist on your 88~91. You can't just 'put it in the tank' like you might do with a fuel pump. Good luck with this tank sensor part.... Everything else about the OBD2 conversion is pretty straightforward.
What is an OBD1 cat? Do you mean a cat with an O2 bung?
Old Mar 6, 2014 | 11:57 AM
boomsplat's Avatar
I knew i had to ref it i was asking if i should take the motor out and put in my motor from my stock ef and smog it
Old Mar 6, 2014 | 12:07 PM
4drEF's Avatar
Keyboard Humorist
If the chassis you want to put the motor in was offered with the motor you want to put in, then the answer is yes.
You can't do things like an D16A6 in a DX. The trim on the DX needs the D15B2 and it will come up in the VIN number check.
Old Mar 6, 2014 | 12:57 PM
boomsplat's Avatar
So then i shoupd put my d15b2 in my series and smog it that way?
boomsplat's Avatar
B series
Old Mar 7, 2014 | 06:26 AM
4drEF's Avatar
Keyboard Humorist
If the B2 was the engine that the chassis came with, then you can.
Old Mar 7, 2014 | 10:47 AM
boomsplat's Avatar
thanks bro you just saved me lots of money and time haha
dtran002
Nov 22, 2011 11:00 PM
97dc2ftw
11
Jul 21, 2011 06:32 PM
NorcalHB94
Jun 23, 2005 09:42 AM
SiRII_Izzy
21
Aug 24, 2004 07:06 PM
HBCthugg
May 3, 2002 11:50 PM
