D15B - blown head gasket and top of cylinders chipped
Old Mar 4, 2014 | 08:45 PM
MrCivic242's Avatar
Default D15B - blown head gasket and top of cylinders chipped
I took apart my D15B because of a blown head gasket and noticed the top of the cylinders were chipped, can someone tell me how this can be fixed?
Old Mar 4, 2014 | 09:04 PM
spoolymcgee's Avatar
Default Re: D15B HELP!
try a thicker than stock head gasket. I not an expert but that might be a less time consuming fix.
Old Mar 4, 2014 | 09:06 PM
MrCivic242's Avatar
If you look close at the outside of the cylinder walls you will see chips at the edges, the inside of the cylinder is fine its not cracked but the chips worry me
Old Mar 4, 2014 | 09:17 PM
how many miles does this engine have? maybe you should invest your time and money in a new block or just a whole new engine. Idk what your going for.
Old Mar 4, 2014 | 09:39 PM
eghatch9295's Avatar
Stancetard Hate Monger
that looks worse inside than the 278k y7 i just opened up. wtf were you using as coolant
Old Mar 5, 2014 | 05:10 AM
Former User's Avatar
Default Re: D15B - blown head gasket and top of cylinders chipped
Replace the block.
Old Mar 5, 2014 | 05:12 AM
JoeBlue's Avatar
Originally Posted by RonJ@HT
Replace the block.
this.
Old Mar 5, 2014 | 05:56 AM
ElectronBlue00's Avatar
Holy.. I don't think I've ever seen it that bad before. Makes be think that the coolant was never changed. But a new block is definitely needed as others have suggested... Good luck man!
Old Mar 5, 2014 | 02:04 PM
MrCivic242's Avatar
Yea I think I'll go with a new block
Ridler3d
Engine Machining & Assembly
Mar 14, 2017 06:15 PM
simpletuning
Classic Hondas
11
Oct 8, 2009 03:53 PM
kc7
Apr 19, 2009 07:13 AM
dunchan1
Classic Hondas
Jun 24, 2008 03:55 AM
