93 civic stArts then shuts off
Old Mar 4, 2014 | 08:10 PM
Shane Henry's Avatar
Default 93 civic stArts then shuts off
The car was idling the stalled off like u turned the key off. When I restart it starts then dies.not like out of gas.i checked the fire at plugs the main rely,injector pulse.and fuel pump and all seem ok.when I un hook map sensor it starts then acts like out of fuel then dies.when I unhooked the injectors it will also run a little better then shuts down after a few seconds like out of fuel.when I hook back up the injectors it will start then strait off.not like out of fuel maby the PCM is bad but don't know. Can someone please help.
Old Mar 4, 2014 | 08:26 PM
PeelYoMuffinCap's Avatar
Default Re: 93 civic stArts then shuts off
Check and clean your iacv... That maybe the problem.
Old Mar 4, 2014 | 08:39 PM
spoolymcgee's Avatar
Check your gas lines? did you take the whole fuel pump out an check it out? strainer bag may need to be replaced.. maybe even bad fuel filter..
Old Mar 4, 2014 | 08:41 PM
carlos8's Avatar
Engine in the car?
Any CEL?
Check fuel filter and FPR.
Old Mar 5, 2014 | 05:14 AM
JoeBlue's Avatar
Check your grounds. It honestly sounds like you're just shorting out, or the circuit is being broken at the main relay, so that would be my first point of digging, by checking the grounds to everything.
Luke 91 ef
Jan 24, 2013 10:40 AM
b17itr
Feb 7, 2011 07:45 PM
Jap_Spec_Imports
14
Sep 26, 2006 02:11 PM
zeke mccune
Jun 12, 2004 05:42 PM
drvfast
May 26, 2004 08:29 PM
