96 cx hatch with y8 swap very loud rumble
Old Mar 4, 2014 | 02:28 PM
digitalvice's Avatar
Default 96 cx hatch with y8 swap very loud rumble
As title says very loud rumble and vibration upon start up and continues to 3500rpm through all gears. Car does need o2 sensor after cat. Exhaust doesn't look like it's vibrating at least not bad enough to create the sound. Also the sound and vibration is heard inside cabin not out of car
Old Mar 5, 2014 | 04:58 AM
Former User's Avatar
Default Re: 96 cx hatch with y8 swap very loud rumble
Post a video with sound.
Old Mar 5, 2014 | 05:02 AM
JoeBlue's Avatar
Did you use aftermarket mounts? If so that is likely the cause.
Old Mar 5, 2014 | 05:05 AM
I just picked the car up the swap was done already I'll post a vid and some pics after work. In pretty sure the mounts are not stock though
Old Mar 5, 2014 | 05:09 AM
JoeBlue's Avatar
Sounds like you may have bought a car with solid mounts. You will get a lot of vibrations and noise in the cabin with solid mounts.
IMO, get used to it and welcome to Hondas.
Old Mar 5, 2014 | 05:15 AM
OP could also re-install the stock mounts to eliminate the rumbling, assuming that the mounts are the problem as seems likely.
Old Mar 5, 2014 | 05:53 AM
JoeBlue's Avatar
More likely the OP will have someone showing him how to change them, but yes that is the best solution for him. Unless he likes the solid mounts. I hate mine, but I like how the car drives with them.
Old Mar 5, 2014 | 07:27 AM
I can change my own mounts. I just wanted an idea of some places to look as I haven't had anytime to thoroughly go over the car. I will still post pics
Old Mar 5, 2014 | 08:17 AM
tony_2018's Avatar
Fish Twig
Well if you can change your own mounts I think that would've been the first thing to look at.
Fr0st479
Mar 13, 2016 11:22 AM
jsnm
Feb 6, 2012 07:37 PM
Sleepy_Red_hatch
25
Dec 20, 2005 05:17 PM
h0tsihatch
Feb 7, 2004 07:44 AM
