Transmission & Drivetrain Gearboxes, Differentials, Clutches
stock exedy organic clutch disc power holding
Old Mar 4, 2014 | 02:09 PM
blackccoupe's Avatar
Default stock exedy organic clutch disc power holding
If I used a stock exedy organic clutch disc with say a aftermarket heavy duty pressure plate do u think it would hold 300 whp. Im asking cause I hate clutch chatter thanks
Old Mar 4, 2014 | 03:29 PM
Runnerdown's Avatar
Default Re: stock exedy organic clutch disc power holding
It may hold for a bit but any kind of abuse will likely render a short life. I got away with a lot on an exedy stage 1 including 23" slick launches but was in the low 200's.
The thing I have found most important for that kind of disc is break in time.
Old Mar 4, 2014 | 03:58 PM
Ic I dont plan on running any slicks anyone else that has run a similar set up
Old Mar 5, 2014 | 06:29 PM
F22Master's Avatar
http://www.exedyusa.com/catalogs/Exe...atalog_web.pdf
According to Exedy, the Stage 1 Organic should hold ~190 ft-lbs to the wheels. The Stage 2 is ~220. But that is with the PP that comes with the kit, But it should give you a general idea.
Old Mar 6, 2014 | 03:29 AM
So I'd be pushing it with the exedy disc guess ill have to try another setup just hate chatter in stop and go traffic
juergen33911
Jul 9, 2008 11:16 PM
H-T guy
Mar 27, 2007 11:58 AM
carlos11
Nov 7, 2005 06:27 AM
Blaze45
Feb 12, 2003 01:57 PM
GSRwBOOST
Jul 23, 2002 08:18 PM
